|WWE|Raphael|.¸¸.·´¯`·.¸¸.- 'Energy' |Jul 13| 21911|23569
Postby nugIedHa » July 17th, 2010, 9:48 am
|WWE|Raphael|.¸¸.·´¯`·.¸¸.- 'Energy' |Jul 13| 21911|23569 - Sense 2.1 /2.5 / MaxSense
Numpang ngopi pes temans2...
Yang punya HTC RaphaeL a.k.a Touch Pro CDMA...en suka diopreks, saia ada rujukan ROM yg mantaf abies en bikin boros batre (lhoh...kekekek)...selamat menikmati... :D
I'm Energy ROM addict...what about U?
[QUOTE=NRGZ28;4132760][COLOR=Blue]Cookie Hometab based ROMs
[/COLOR]
Cookie 'Energy' style
  • This is the best ROM version and the way Sense should have been designed by HTC
  • Offers the biggest customization ability out of all versions. You can add/remove bars or items, arranges items on the homescreen any way you like
  • Three built in lockscreens. "HD Mini" style, Manila style or Windows style
  • 3 pages of quicklinks with configurable amount of shortcuts displayed
  • 3 Homescreens to choose from, as seen in the above screenshots, all completely customizable !
  • Link to the original thread for this mod is here > Click <
Cookie Dinik (glassy theme)
  • This is the same as the Cookie version above, but with Dinik's glass theme applied on everything.
  • Everything has been skinned, including Sense, the start menu items, the soft keyboard, parts of the dialer... etc
Cookie GTX (white theme)
  • This ROM has the white GTX theme applied.
  • Android styled taskbar
  • Matching dialer
  • Matching start menu background and Action screen background
  • GTX is a total reskin of the operating system, so expect a very different experience
  • This series retains the stock functionality of the Sense UI. The files have been compressed by "CFC" compression. making the UI lighter and faster.
  • You have the choice of two styles.. "Energy" style where everything is blue and there's plenty of nifty apps cooked in, or "Reference" style where Sense is stock,
MaxSense UI
  • This the next incarnation of MaxManila, but a TOTAL departure from the original design.
  • It features a 3 screen, Android style, homescreen with widgets! The widgets can be placed ANYWHERE on the three screens.
  • 75 Quicklink accessible on all tabs
  • You should really visit the original thread for this mod shown on the next line to see all the features!
  • Link to the original thread for this mod is here > Click <.
TITANIUM OR SENSE 2.1/TITANIUM
  • This is a minimal ROM version without Sense in it. It's used primarily for people that like to customize the default 6.5 homescreen (Titanium)
  • You can use it to install alternate homescreen interfaces like SPB Mobile Shell, etc
  • Very low memory footprint and good battery life, but very simple and lacks a lot of features that you would otherwise have available in Sense...
http://www.energyroms.com/Addons/Return%202%20Stock%20CABs/
[/QUOTE]
source : http://forum.xda-developers.com/showthread.php?t=536751
|C45-1/2XP|M55-XPv2|M6V@CX70-XP|M75@CX75-XP|SK6R@SK6C-XP|SL42@Paradisev3.8+dBE PH10*PA20|SL75|
|HTC_RaphaeL_CDMA@Energy ROM|
|HTC_Diamond_GSM|nunggu LCD|
|HTC_RhodiumW_CDMA_ono GSMe@Energy ROM + Gingerbread + Ubuntu 9.04|
nugIedHa
Re: |WWE|Raphael|.¸¸.·´¯`·.¸¸.- 'Energy' |Jul 13| 21911|2356
Postby REC*303 » July 17th, 2010, 2:30 pm
^^ mas ini buat SX66 bisa gak?
Postby Joy » July 18th, 2010, 1:27 am
:x :x :x
jadi pingin PDA, :( :( :(
raphael bisa smart gak pak nug?
Postby nugIedHa » July 18th, 2010, 1:44 pm
@mas Rec...yo nda iso...itu ramuane dah khusus...pakai Rom buat yg HTC blue angel.
Coba cari di forum.xda-developers.com om...ane blum ketemu linke niy...
@pak Joy...beli donk...kekekek...
kebetulan Touch ProKu yg CDMA version...dual band...dah suprot EVDO REV.A pula...dijamin Wuuuzzzz kalo pake SMART.
Kebetulan ane cuman pake PREN..mindah hp slimo yg dah ancur.
nugIedHa
Postby kokakokbrut » July 20th, 2010, 3:57 pm
ini bisa bwt PDA merk apa aja ???
Postby Joy » July 20th, 2010, 6:50 pm
@ pak nug, masih mahasiswa ni, hehehe
lgi ngincer pda tapi bingung apa yang murah, :D :D :D
Postby nugIedHa » July 20th, 2010, 7:02 pm
@ mas Kok...ya bisa buat Touch Pro aja..hahaha...
buat yang lain silahkan ke http://forum.xda-developers.com/
macem2 ROM tersedia buat PDA yg macem2 pulak...
@pak Joy...ane jg pernah ngalamin...
waktu mahasiswa ane cuman pegang C45 dikasih kakak...mau lulus pegang M55 dikasih kakak pulak... :))
klo PDA yg murah beli yg kiloan aja mas...jangan yg batangan...masih mahal juga soale...kikikik
nugIedHa
Postby nugIedHa » July 20th, 2010, 7:05 pm
@ mas Rec...dapet link buat Blue Angel en sejenisnya niy...macem2 ROM buat SX66 tercinta ada di M.A.R.E
nugIedHa
Postby Budi_XP » July 20th, 2010, 10:42 pm
nugIedHa wrote:@ mas Rec...dapet link buat Blue Angel en sejenisnya niy...macem2 ROM buat SX66 tercinta ada di M.A.R.E
Mantabs segera pakai sx66 lagi :)
Postby nugIedHa » July 21st, 2010, 5:10 am
sikat mas Boed...
oya, bodolan part SX1 yg mau dihibahkan msh g bro?
nugIedHa
Return to Windows Mobile
