(Share) Aplikasi Gratisan (Antivirus, Spyware, Firewall etc)
Postby REC*303 » March 11th, 2010, 2:26 pm
Berhubung saya hobi koleksi antivirus, jadi pengen share dikit2. daripada pakai barang bajakan yang dijadikan ori (sambil ngelirik mas Citra_TZM) so...
AVAST 5 Free Edition wrote:System Requirements
Processor Pentium 3, 128 MB RAM, 100 MB of free hard disk space
Microsoft Windows 2000, Microsoft Windows XP/Vista/7 (32/64 bit)
Antivirus and anti-spyware engine
State of the art scanning engine provides reliable protection against viruses, spyware and other forms of malicious software.
Real time anti-rootkit protection
Unique "on access" technology checks all kernel-mode drivers that the operating system is loading for signs of rootkit behavior. This enables even unknown rootkits to be detected and stopped before they can do any damage.
avast! Community IQ
Most samples we process come from sensors deployed throughout the avast! community in the Behavior shield and anti-rootkit modules. This is a unique source of data made possible only thanks to our huge user base. Most of the collected samples are analysed by a number of automated processes and only a small fraction of the samples need to be processed manually by our virus analysts.
Code emulator
When a suspicious executable is encountered (during both on-demand and on-access scanning), avast! is able to emulate the program’s code in an isolated environment. The code emulator is used for two purposes. First, it is used for generic unpacking. Secondly, it is used in the heuristics engine. Technically, this is done using dynamic translation, a method much faster than traditional emulation techniques.
Heuristics engine
Starting with version 5.0, avast! features a new heuristics engine designed to proactively detect malware undetectable with normal definitions. The heuristics engine is able to cover both binary (executable) and script malware.
Potentially unwanted programs detection
New in version 5.0, avast! now detects potentially unwanted programs, such as remote admin tools and commercial key loggers. Custom rules can be set for dealing with these types of programs.
Boot-time scanner
Allows you to scan your computer for infections before the operating system has started and before a virus can be activated (32-bit operating systems only).
Wake-up for scan
Microsoft Windows is woken from sleep or hibernation mode, performs a scheduled scan, then returns back to sleep mode.
Scheduled scanning
Allows users to define the scan time and files to be scanned.
avast! Intelligent Scanner
Can reduce the number of required file scans by up to 80% through a white list of proven safe applications. Files identified as safe are not rescanned unless they change.
Behavior Shield
Monitors activity on your computer using a number of sensors (file system, registry and network based) and reports/blocks any suspicious behavior.
Behavioral Honeypots
avast! sensors identify and monitor suspicious file activity on selected computers, automatically submitting files to the Virus Lab for additional analysis.
File System Shield
Real-time scanning of opened/executed files.
Mail Shield
Scans all incoming/outgoing e-mails for malware. For MS Outlook, a special plug-in is used. Other email clients are protected by a generic POP3/IMAP4/SMTP proxy. New in version 5, the proxy also supports scanning of SSL communication (gmail.com, sympatico.ca, ….)
Web Shield
Scans all visited web pages and checks all files, pages and java scripts downloaded from the internet. Thanks to the Intelligent Stream Scan feature, the Web shield doesn't slow down your web browsing.
P2P Shield
Checks files downloaded using P2P programs. - ABC, Ares, Azureus, BearShare, Bit Torrent, BitComet, BitLord, BitPump, CZDC++, Direct Connect, eDonkey, eMule, iDC++, iMesh, Kazaa, Kceasy, LimeWire, Morpheus, Opera's DC++, Overnet, Qtrax, Shareaza, SoulSeek, StrongDC++, uTorrent, Vuze, WinMX, Winny2, Zultrax.
IM Shield
Checks files downloaded while using instant messaging or “chat” programs. - AIM (AOL Instant Messenger), Gadu-Gadu, gaim/Pidgin, Google Talk, ICQ, IM2 Messenger, Infium, Miranda, mIRC, MSN/Windows Messenger, Odigo, PalTalk Messenger, Psi Jabber Client, QIP, QQ, SIM, Skype, Tlen, Trillian, WengoPhone, XFire, Yahoo! Messenger.
Network Shield
Provides protection against network-based viruses. The module has two main components: a URL blocker, designed to block malicious URLs (as defined by the Virus Lab), and a lightweight intrusion-detection system.
Smart virus definition updates
Incremental updating system minimizes the size of regular update files.
Fast application of updates
New format for the virus definition file speeds up application of updates into avast! 5.0 and reduces demand on CPU/memory, resulting in uninterrupted computer use.
New format for the virus definition file means faster updates and reduces demand on CPU/memory, resulting in uninterrupted computer use.
Silent/Gaming Mode
New Silent/Gaming Mode automatically detects full-screen applications and disables pop-ups and other on-screen notifications without degrading security.
Optimized for latest Intel Core i7 CPUs
Critical sections of the avast! scanning engine code have been optimized to deliver unrivaled performance on the latest Intel chips.
Multi-threaded scanning optimization
avast! runs faster on new multi-core CPUs. A new avast! feature allows the splitting of large individual files between cores, accelerating the scanning process.
Green computing
Reduced demands on the disk drive result in lower energy consumption.
avast! iTrack
Real-time graphic scanning reports.
Graphical user interface
Easy to navigate graphical interface.
Automatic processing
Infected files are processed automatically without requiring user instructions.
http://www.4shared.com/file/tJk9mPcp/wjehuwehfnrhgirehgi.html
antivirus ini sangat ringan bagi kompi yang mempunyai spek rendahan, so recommended lha... yang penting gratis
IObit 360 Security Free Antispyware and Trojan Remover
Postby REC*303 » March 11th, 2010, 2:38 pm
Buat ngelengkapin antivirus bisa pakai ini, yang penting free
[quote=]
Key Benefits
* Work with All Antivirus Products
Everyone needs a qualified antivirus software, and Security 360 will surely be the best mate for your current Antivirus.
* Complete PC Security Care
Anti-malware, anti-spyware, anti-adware, anti-Trojan, anti-bots, and more. Security 360 can assist# your Antivirus to defend any tricky and complex threats.
# Currently, there is no solution that offers a 100% effectiveness rate for detecting virus and malware. You may become a victim of misleading advertising, if you buy such a product under those premises.
* 1-click Solution and Very Easy to Use
Traditional advantages of IObit products. We love simple and automatic styles.
* Very Fast and Light
Thanks to the unique "Dual-Core" anti-malware engine, complicated analysis can be made faster now.
* Finds the Deepest Infections
Using DOG (Digital Original Gene), a novel heuristic malware detection method, Security 360 can find the most complex threats.
* Automatic and Frequent Updates
By the new-generation malware analysis system and our professional database team, Security 360 catches the emerging dangerous malware in the Internet.
* Free for Home/Non-commercial Use
Scan & Remove is free, and real-time protection is free too. You will love this small but powerful free anti-malware genius.[/quote]
Saya udah nyoba sih tapi entah apakah ini ampuh :?:
http://www.4shared.com/file/238727467/7256008a/is360setup141.html
Windows7 firewall Control
Postby REC*303 » March 12th, 2010, 10:47 am
Dengan menggunakan firewall bawaan microsoft yang terinstall secara default, aplikasi ini memungkinkan kita untuk lebih pro aktif lagi dalam memaksimalkan windows firewall yang biasanya kalem2 ajah :
Download setup :
http://www.4shared.com/file/238798025/d08e2d39/Windows7FirewallControl-Setup-.html
Re: (Share) Aplikasi Gratisan (Antivirus, Spyware, Firewall etc)
Postby inoetea » March 12th, 2010, 7:00 pm
^ =D> Nais inpoh, Mas. Ada lg? :) NIS 2010 & KIS 2010... ;;)
Postby REC*303 » March 13th, 2010, 12:06 pm
^^ wah, saya cuman nyediain yang gratisan aja mas :D
tapi saya bingung koq file2 yang di upload di 4shared ini suka kehapus sendiri ya? ada apa ya kira2... :-S
Postby kokakokbrut » March 13th, 2010, 5:17 pm
klo file exe sih suka ada diskriminasi, klo ga dianggap ada file crack ato virus.
coba direname extensi file nya aja
Postby REC*303 » March 13th, 2010, 8:17 pm
^^ oh gitu ya...?! okelah entar saya coba hapus semua untuk kemudian di upload ulang dengan ekstensi rar. sementara link yang ada dihapus dulu
Postby Citra_tdz » March 14th, 2010, 3:30 pm
REC*303 wrote:Berhubung saya hobi koleksi antivirus, jadi pengen share dikit2. daripada pakai barang bajakan yang dijadikan ori (sambil ngelirik mas Citra_TZM)
wakiakiakiakiakia... peace deh mas, aku emang suka pake yg bajakan, tp juga mendukung anti-piracy campaign kok mas, jd jngan ditangkap ya... xixixixixi...
btw, nick ku bukan TZM mas, tp citra_tdz... dah 3 hari ga cek forum (tempat ku buka forum beberapa minggu ini lambat bngt, kenapa ya...), ternyata ada yg kangen, hehehehe...
klo Avast aku rekomen bnget deh, pernah install buat temen yg v.4, ga pernah ada masalah tuh, n ringan bangt... sejak keluar yg v.5, aku ganti instalin yg prof edition, so, bajak lagi deh, he.... tp yg free n prof edition ga tau apa bedanya, aku liat sama aja, sama2 bagus n ringan... rekomended deh...
klo firewall windows 7, aku yakin juga bagus, selama ini firewall default windows cukup bagus... tp dah lama aku ga pake, soale antivir yg aku pake dah ada firewall nya...
so, yg free bukan berarti ga bagus, bnyak bnget program free n opensource yg bagus2 n bahkan ada yg lebih baik dari pada yg paid... klo ada yg free n bagus, knapa harus bayar.... (tp kok aku tetep seneng make yg bajakan ya, bahaya nih, rasanya ada prestise tersendiri pake program2 bajakan, wah, aku jd kriminal dong, help....)
peace ya mas Rec....
Citra_tdz
Postby Citra_tdz » March 14th, 2010, 4:20 pm
Citra_tdz
Postby kokakokbrut » March 14th, 2010, 7:46 pm
klo AV buat jendela si sayah lebih rekomen ke ansav+clamav
tapi ansav rugi nya susah banget update nya padahal bagus tuh.
AV lokal yg ada plugin clamav apa ya, PCMAV jelek
Return to Windows OS
