• CALIBRATING YOUR BATTERIES •
Postby Hendz » March 16th, 2012, 8:37 am
This was originally came from ma menthor Master Shantanu a.k.a. Shanty in MMUS.us , a bit edited by me to easy understand and do. And this should be work perfectly for ALL phones that run with batteries.
REMEMBER THIS WILL NOT DRAMATICALLY IMPROVE YOUR BATTERY-LIFE BUT....
WILL SAVE YOURS FROM DEAD-BEFORE-AGE !
AND DO NOT EXPECT MORE FOR ALREADY SWOLLEN, PREGNANT,,,OR DIED BATTERIES EVEN!!!
Well, the battery calibration is simply so easy:
1. Run your phone completely til it shuts off by itself.
2. Remove the battery, wait for 10 seconds, insert it again, repeat, til it's really really empty and can't started anymore.
3. If the phone shuts again in less than a few minutes, that's good!
4. Now remove battery and hold your Power button for ONE minute, or more.
5. Insert back the battery but
DO NOT switch-on the phone yet! Just plug the charger and recharge the battery, wait til it's fully charged, no matter the time!
6. Remove battery, hold Power button for just few seconds, insert it, then switch the phone on.
7. Yea you're done!
Do this initially once in 3--4 months only if your phone is of new-purchased one.
Then do this again only for once-a-month-after-a-year to gain maximum battery performance.
What I've been thru?
Just as you see Shanty said it must be at least once-a-month after a year but I got maself done this for once-in-3-month actually :-) and it works good for me I swear... - I played ma musics while browsing the net continuously more longer than before, but don't try this while you can't)
So guyz, you take care your battz carefully! No matter what!
And don't push it to work so hard even when you're in the middle of something on the phone,,,for the good n original batteries are not so cheap enough to us..........
Good luck! :-) :)
Re: • CALIBRATING YOUR BATTERIES •
Postby mamed_3279 » March 18th, 2012, 1:29 pm
jadi maksudnya bener2 ngosongin batre yah mas..ato bener2 ngilangin energi dari hp :D
dulu saya sering nih begini..tapi sekarang udah ga sempet lagi :(
Postby TUFF Stough » March 18th, 2012, 1:46 pm
Keknya itu perlakuan untuk batere metal, kalo batere Li-ion bukannya gak boleh sampe kosong banget?
Postby Hendz » March 18th, 2012, 1:48 pm
bkn ngosongin batre maz :)) tp ngatur ulang [kalibrasi] tenaga batre supaya ion2 lithiumna encer rata ke sluruh tubuh cell na, jd dpt performa power yg maksimum, ,,, ,sama aj kyk di DEFRAGment :-D
slain itu jg elektrostatik2 yg nempel di tmbol power ama yg di kondensator2 eLco di mesin hape pada ilang/netral,,, jadina mesin bnr2 kosong tanpa ad sisa energi elektrik. -- dgn cara bgini, kata master Shanty mesin jd lebih awet and batrena jd tahan lama (tp emang bener sih), palagi kalo batrena baru, kan sayang klo cepetan rusak cm gara2 dipake terus tp ga pernah dikalibrasi. emang sih ga bnyk yg tau tp nich tipz yg mantap :-) ....aq jg ada tipz yg rada aneh soal ngebasahin ion2 lithium yg dah mulai kering loyo ga pny power lg..
________________
Send from Milestone using Tapatalk
Postby Hendz » March 18th, 2012, 1:51 pm
justru ni utk lithium maz :) pny q dari BP6X, BR50, smp EBA pny siemens m65 jg gpp koq.... yg di s-25 jg aq gituin smua..,,, dah jln 3 bln ni gpp
Postby Hendz » March 18th, 2012, 1:57 pm
STEP
ntu sbnrna ga 100% bikin batrena jd kosong koq,,, klo ditest ama avo-meter jg msh ada tegangan bbrp volt.
jd oke oke aja dech pokokna :-)
--have nice weekend.........
Return to Modding Aksesories
