s10d active
s10d active
Postby orang jauh » September 14th, 2010, 10:40 am
siemens s10d active saya kena phonelock, apa harus di flash? kabel nya make tipe apa ya? apa ada cara perbaikan nya lewat pencet keypad kaya hape-hape NO**A gitu? trims. :-/
orang jauh
Re: s10d active
Postby gandalf » September 14th, 2010, 2:30 pm
software buat unlock dah susah, palagi kabel datanya :( nunggu mas hendz smoga aja bisa
Re: s10d active
Postby kokakokbrut » September 14th, 2010, 8:06 pm
Warning: Do not enter any wrong unlock unlock codes on your Siemens S10 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Siemens S10 with a NOT ACCEPTED SIM Card.
2 - Compose : *#0000*CODE#.
(OR)
2 - Compose : *#0001*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Siemens S10 is locked to.
CODE: The unique unlock code for your Siemens S10.
Each Siemens S10 mobile phone has an unique unlock code. You can buy the unique unlock code for your Siemens S10 mobile phone at www.mobileunlocksolutions.com.
sumber http://www.mobileunlockguide.com/siemens-s10
Re: s10d active
Postby Hendz » September 16th, 2010, 7:55 am
Don't even think you buy anythin' from web to unLock, just think by yerself a "code" :D
Coba yg ni bisa ga? ---> cabut simcard truz masukin *#0003*00000000#
Re: s10d active
Postby orang jauh » September 20th, 2010, 2:10 pm
dapet code nya dr mana ya mas? apa harus beli? soalnya dicoba pake phonecode yg saya pake di hp ini malah ditolak terus. ga bisa. jd bingun :(
orang jauh
Re: s10d active
Postby kokakokbrut » September 20th, 2010, 7:08 pm
pake angka 0 aja
Re: s10d active
Postby REC*303 » September 20th, 2010, 7:24 pm
jadiin pajangan aja kalo memang terkunci selamanya
Return to Older
