FUBU SL4X
FUBU SL4X
Postby threepong » October 13th, 2010, 12:55 pm
threepong
Re: FUBU SL4X
Postby Budi_XP » October 17th, 2010, 12:33 pm
wah akhirnya ada fubunya juga saya baru punya sl42 Load Game Vodafone jd gak khawatir kalo ada trouble :)
izin nyedot mas :D
Re: FUBU SL4X
Postby threepong » October 18th, 2010, 10:31 am
monngo mas Budi .... btw dah nyoba Heaven 1.2 ini agak beda dr Paradise coz base dr unipatch 2 .... dr test lebih oke dr paradise lebih cepat dr paradise walau suara mp3 gak sekenceng paradise tp lebih bening btw hrs ditambah patch yg buat mmc 2GB biar tambah makyus ..... dah support xtask jd bisa atur mp3 dr homescreen :)
ini pelengkapnya ada isi mmcnya tp lom sempet diupload ...
threepong
Re: FUBU SL4X
Postby Budi_XP » October 18th, 2010, 1:55 pm
Oke Mas thank you :)
Re: FUBU SL4X
Postby herry_potter » February 14th, 2011, 11:30 am
@mas threepong, sudah coba paradise_ferrari? Katanya bisa support MMC 2GB, playlist > 30 songs, batere lebih stabil, keyboard AikoN.
Re: FUBU SL4X
Postby threepong » February 14th, 2011, 12:34 pm
@ Herry
Lom sempet maen2 ke SL4x nich :) nanti deh dicobain ...
Thx infonya ...
threepong
Re: FUBU SL4X
Postby Boowin » February 14th, 2011, 2:02 pm
ijin sedot mas threepong, wah mantab nih. coba d'apply ke SL45'q ah..... :D :D :D
[thanks] <----- sambil klick tombol thanks, hehehehe........ :P
Re: FUBU SL4X
Postby herry_potter » February 14th, 2011, 4:07 pm
ternyata sl4x ku diflash pake fw. heaven 1.02, lebih soft dibanding fw. paradise_ferrari...
Re: FUBU SL4X
Postby Boowin » February 15th, 2011, 8:50 am
mantab nih heaven, tp kenapa ya klo hp d'restart bahasa'nya selalu kembali k'bahasa vietnam.....???? :?: :?: :?:
Re: FUBU SL4X
Postby herry_potter » February 15th, 2011, 9:36 am
sl45i ku stlh di flash pake heaven 1.02, kalo di turnoff atau restart gak reset ke bhs vietnam. tapi kmrn sempat reset ke bhs vietnam stlh fullcharged dan switched off. coba diapply *#0045# lalu tekan tombol call.
