SL42 SL45, beda dimana
Postby mBenQ » May 28th, 2010, 1:10 pm
sesuai judul trit, mohon infonya tentang perbedaan kedua hp tersebut
thx b4
Re: SL42 SL45, beda dimana
Postby gandalf » May 28th, 2010, 1:25 pm
Siemens SL45 was the first mobile phone with memory expansion and an MP3 player, which debuted in 2001. An improved version, the SL45i, was also the first phone to have a Java virtual machine.
Version
The Siemens SL45 came in three versions:
Siemens SL45 - original edition, with a 32 MB memory card, sync station and stereo headphones in the package
Siemens SL42 - a cheaper version introduced later, with a 16 MB memory card and no sync station or headphones
Siemens SL45i - a version with a new firmware with Java support, and a slightly stronger battery
These three phones are electronically identical, and the SL45i's firmware can be installed in the SL42 and SL45, thus enhancing them with a Java virtual machine.
mudah2 an sperti itu jawabannya :)
Postby mBenQ » May 28th, 2010, 1:37 pm
oh aisi aisi...
jd SL42 adalah versi murah SL45 yang
1. dalam paket penjualannya tidak menyertakan SyncStation dan headphones
2. MMC bawaan cuma 16MB
begitu kan?
Postby gandalf » May 28th, 2010, 1:45 pm
ya :)
Postby kokakokbrut » May 28th, 2010, 2:59 pm
eh nanya dong
sl45/sl42 kan support java
maxudnya tuh bisa dimasukin aplikasi java (.jar) ke hp ato OS nya java ?
Postby TUFF Stough » May 28th, 2010, 7:57 pm
Artinya bisa pake aplikasi java, bukan OS java.
Postby gandalf » May 28th, 2010, 8:14 pm
mestinya bisa sih. tp ga tahu lagi . jarang explore sl45 sih .
Postby kokakokbrut » May 29th, 2010, 12:56 am
ada yang pernah coba masukin apliasi java ke sl45??? hasil nya gmn???
Postby mamed_3279 » May 29th, 2010, 2:07 am
kalo dari penjelasan mas gandalf (english version),bukannya yang udah support java cuma SL45i??
kalo ga salah saya pernah install java di SL45i,tapi ga berhasil..mungkin ketinggian kali versi javanya :D.lupa juga waktu itu java apaan :D
