Fubu Western Edition 2011
Postby smitho » April 1st, 2011, 4:24 pm
Permisi Para XPier Skalian........ :D
kali ini saia mencoba untuk berbagi fubu baru dengan anda skalian...... B-
http://www.mediafire.com/?sb8v8yj6ruveg
mnurut informasi yg saia baca fubu ini dibuat oleh yg buat Fubu Paradise......
konon katanya begitu........
saia masih belum sempat mencoba.......
monggo para XPier coba sendiri dah.....
setelah itu monggo dishare dimari hasil percobaannya. :D =D>
Sumber : http://www.sl4x.com
SL 42, SL 45, SL 45i, SL 55, SL 65, SL 75, C 55, A 60, M 35, ME45
smitho
Re: Fubu Western Edition 2011
Postby andRa4 » April 1st, 2011, 4:33 pm
ini pubu bwat sl4x yah-??
Postby smitho » April 1st, 2011, 6:34 pm
andRa4 wrote:ini pubu bwat sl4x yah-??
iya mas buat SL4X............
:D :D :D :D :D :D :D :D :D :D :D :D :D :D
smitho
Postby jaketmerah » April 1st, 2011, 9:52 pm
Hasilnya gimana?
Postby herry_potter » April 2nd, 2011, 5:41 am
Sudah saya flashing ke sl45i, setelah di switch on, langsung masuk
pada kondisi "screen locked". Metode unlocknya beda shg belum bisa diexplore....
Postby herry_potter » April 2nd, 2011, 6:12 am
He...he...sudah ketemu unlock passwordnya : 153
Berikut mbah google translation untuk article SL4x Western Edition 2011 FUBU :
Western Edition 2011 - the same discovery!
- "The Mummy Returns": a fubu ancestry "old" (2008), but was awakened again, but completely new in every way, from architecture to the quality ...
- Made in China: it is so; still a lot of English China, and is very uncomfortable. Tried but failed to overcome because there is not much time.
- Advantages: sound quality may be robust, caught fire, with Vol 28 (months before the test do not remember too clearly).
- Structure: the combination of these nearly 400 utilities patch, patch. Also anything related to 3G technology, but I have not understood this.
- Author: who also made the Paradise from the past to present.
- Comparison: This release however is the same author but have not used DC patch on the original language of Paradise. Compared to Paradise v5.0 will probably be compared only on sound quality. What about features they may not be perfect as the Para, but also Western aplication 4, virtually all the main features will not lose anything Para.
- Move quickly from China to Tiếng Việt language: * # 0000 #
- Pass: 153 - "Some of the FLASH code: Unlock code" 153 ", message encryption password" 65535 ", JAVA Personal Finance Code" 123 ", more than one card entry code" 1130. "
This is a new experience for you to play SL!
Do you have the same test to find out the advantages and the unique features of this nhé!
(The above is a subjective comment, hope you study the same test to discover nhé!)
Test results.
1. Filled newspapers batteries (avoid bottle battery) a little bit machines automatically report when fully charged batteries (even rechargeable shutdown). If charged at night they can sleep a little bit lost, but the battery is not damaged ....
2. Mp3 vol 28, listened to, not shy with the headphone output "big." Also sound quality depending on how people feel ...
3. [Herotapchoi] Press the button on the handset it appears that it does not stop calling. matbao8x - This is so, ae should copy all the applications on a memory card to see if DC can not overcome.
4. [Herotapchoi] sometimes ambiguous display screen awkward (not to loose my home screen), especially when it's in mp3 or so, and then press the button to escape back into the new DC.
5. [Herotapchoi] Indian menu to the left of the table but you are in there on the DC. matbao8x - ae This should copy all the applications on a memory card will be sure to fix the problem.
6. Too many English ships, though they have moved * # 0000 #. matbao8x - If more people would use his translation of this research.
7. [Herotapchoi] The parameters appear on the screen as well as the mp3 problems too that I did not understand the parameters that means anything. matbao8x - This is a new feature of this edition, I felt quite reasonable Mp3 interface, with its own definition. Although somewhat complex but can understand Address
8. matbao8x - Invite you to test, nothing new I always update.
Introduction ---------------- (google translation)
This publication was produced in late 2008, during off after two years (including in Xinjiang can not send and receive text messages for 6 months and 10 months off the network), also a was like giving up, but the enthusiasm and support for 3G loyal 6688 the number of items displayed area code of data availability, to strengthen my resolve to continue to do so, most recently in the cloud mm finally resolving the help of screen when charging the characters may not show problems early on, and let this version better. Thank you so much in this patch Masters Forum 0110 patience and loyal support long-term 6688.
This version combines nearly 400 utility patches, patches, source: This Forum masterpiece all patch, patch management, Patch Paradise package.
Rich: key features, including area code showed that the patch 3.2 (and support for 3G data update only the area code number 20100906), CDR 2.3, QQ and the latest series of time Power-off protection is not blocking the display alarms to solve problems in electrical systems;
Deluxe interface: Dual graphics applications, dynamic clock standby, and two standby, the clock still, according to background can be displayed in different styles JAVA standby icon, background, status MP3 playback icon, voltage and current, temperature, signal strength, area code, time, etc.; ever MP3 player interface (which may look a bit messy); rich off the screen, in addition electricity and can display a large clock outside the boot welcome, days, weeks, hours, temperature, voltage, power plays a rich interface with time of standby.
Intuitive, easy to use: Basic does not hide the menu, almost all the features of WYSIWYG, which is available through menu operation. Dual-graphics version of the menu graphic menu in Para, all kinds of symbols and functions in a flash, JAVA package compatible with version 99% of Para, Para's JAVA packages can directly use for this version (mainly my own laziness, no better idea to modify the graphical menu.)
Apart from displaying the code data, all other patches are not accounted for 580,000 ~ 5B0000 address space for future expansion of the database display area code to provide enough space.
__________________
People always play nice ... SL4x! ...
Postby smitho » April 2nd, 2011, 7:16 am
@ mas herry : trims mas saia lupa nuliskan kode unlocknya dimari :"> :"> :"> :"> :"> :">
trs gimana mas,udah diexplore?tolong dishare ke kita2 dong..... :D :D :D
smitho
Postby herry_potter » April 2nd, 2011, 10:39 am
Kira-kira sudah 4 jam pakai firmware ini. Sejauh ini stabil.
Saya pakai yang Western Edition 2011 VN. Ada juga yang versi EN, tapi apakah full english? kurang tahu...
Indikator batere dapat mencapai 100%.
Explore di MP3 player, tampilannya complete screen :
- tahun, bulan, tanggal, jam, menit
- batere : volt & mA, temperature
- indikator vol. 0-28 steps
- indikator repeat dan shuffle
- indikator untuk MP3 : rewind, play, pause, fastforward
- indikator bass B0-B3, pitch H0-H3
Salah satu yang menarik, step volume dibuat cukup halus dan bisa diatur
hingga suara sama sekali tidak terdengar vol.0.
Sayang bahasanya Vietnam jadi ada beberapa item yang nggak ngerti.
Tetapi overall, sejauh ini ok punya...
Cek *#06#, IMEI nya 8888 8888 8888 885, version Western Edition 2011.
Oh ya untuk flashing agak sedikit sensitif waktu tekan tombol on (merah), jika flashing dari
Western Edition 2011 ke FUBU ori atau FUBU yang lain. Perlu beberapa kali tekan
tombol merah sebelum terbaca oleh Vklay...sabar aja pasti bisa.
Postby Boowin » April 3rd, 2011, 2:59 am
wuih mantab nih, donlot dulu ah. besuk mau coba d'apply ke SL45 punya'q yg satunya...... :D :D :D
Postby smitho » April 3rd, 2011, 8:13 am
silahken dicoba mas Boow....... :D :D :D
smitho
