patching c55
patching c55
Postby ronixp » July 16th, 2011, 3:03 pm
tolong rekan2 semua,aku coba nge patch c55 selalu gak sukses.gimana ya caranya?.thx.
ronixp
Re: patching c55
Postby ilham » July 16th, 2011, 3:15 pm
Gak suksesnya di bagian mana ya, Kaka?
Re: patching c55
Postby Boowin » July 16th, 2011, 7:58 pm
versi patch sama firmware hp beda kali....???
Re: patching c55
Postby ronixp » July 17th, 2011, 9:54 am
begini,.patch&fw hp udh sm vrsi 24.trus waktu apply bs diterima,tp stelah selesai,sy coba nyalakan hp bs stanby tp cm sekitar 2menit,hp langsung mati,dan ku nyalakan 'wrong sofware'.buat rekan2,ada yg pernah sukses ngoprek c55 gak?.
ronixp
Re: patching c55
Postby ilham » July 17th, 2011, 10:31 am
Saya belum pernah patch C55, mungkin rekan2 di sini sudah, ada yang bisa share?
Patch yang diapply apa saja ya, Kaka?
Re: patching c55
Postby ronixp » July 17th, 2011, 11:21 am
patch nya jam digital yg gede di layar stanby,&font.
ronixp
Re: patching c55
Postby ilham » July 17th, 2011, 12:28 pm
Dari: PENTING: BACA INI SEBELUM MEMULAI FLASHING & PATCHING !!
Sering terjadi pd patch graphics yg menggunakan address "FFFFFFF", berarti anda harus merelokasi PIT addressingnya utk menggunakan address lain yg FREE.
Tapi saya belum tahu caranya merolakasi PIT address :D
Patch grapik memang suka ga cocok.
Kebanyakan patching dibuat untuk FW LG03 (Rusian), coba pakai FW LG03.
Re: patching c55
Postby ilham » July 17th, 2011, 1:09 pm
Digital clock on the main screen
;For the stripped-down langpack
; Not be used together with other patches digital clock! (And maybe you can, and sundry, check)
; First roll back the old version
; Requires patch "increase in the number of images in the PIT"
increase in the number of images in the PIT (C55v24) --> http://patches.kibab.com/patches/dn.php5?id=2400
Re: patching c55
Postby ronixp » July 17th, 2011, 7:41 pm
oke mas ilham mkasih atas bantuannya.skarang c55 ku sip,patchig sukses.he..he..he..
ronixp
Re: patching c55
Postby ilham » July 17th, 2011, 8:11 pm
Sama2, Kaka.. :D
