M65 Firmware Update Problem
Postby herry_potter » July 19th, 2010, 3:40 pm
Saya coba update M65 dari firmware 12 ke 50...tetapi belum berhasil.
Ada pesan error : "Secured updated not possible, device not prepared".
Hal ini terjadi baik pakai WinSWup maupun Update Tool.
Di sisi lain, data cable DCA-510 terdeteksi sebagai DCA-500 pada M65,
tetapi pada M75 terdeteksi sebagai DCA-510. Aneh tapi nyata!
Mungkin ada XPiers yang pernah punya problem yang sama?
Already SOLVED
Finally I can update my M65 Rescue to firmware ver.16 with WinSwup smoothly.
Thanks to Sotaland for your friendly support. The steps are quite long and tired.
Thanks also to siemens-xp member who gave me advise and support.
I update from 12 ---> 16 ---> 44 ---> 50 successfully.
Here are my steps and first time I use "Format FFS" tab. Very dangerous in fact.
You can try this...but in your own risk!!!
1. Phone in off condition.
2. Connect to PC with DCA-510
3. Run PapuaUtils
4. Open Settings tab and click on “Service Mode”
5. Short press red button
6. Go to Various tab and click on “Read IMEI”
7. Click on “Freeze” and error happened “In this mode Feeze not possible”
8. Switch off phone
9. Switch on phone
10. Go to Codes tab and click on “Read code” (ESN and HASH will fill in automatically)
11. Fill SKEY field with 12345678
12. Click on “Calculate HASH and BootKEY from ESN + SKEY”
13. Switch off phone
14. Go to Flash tab and put check-mark on :
- In Flash
- In Bcore
- 76, 5008, 5009, 5077
- Master codes
15. Click on “Do the Job”
16. Short press red button
17. Go to Settings tab and click on “Service Mode”
18. Shortpress red button
19. Go to Various tab, click on “Read IMEI”
20. Click on “Freeze”
21. “In this mode Feeze not possible”
22. Open FFS Format tab
23. Click on “BCORE”
24. Click on “Yes”
25. Click again on “Yes”
26. Wait…
27. Push red button to switch off phone
28. Push red button and wait 2 – 5 minutes (Nothing happened on the phone. Just wait!!!)
29. Go to “Flash” tab and put check-mark only on “New BCORE”
30. Click on “Do the Job”
31. Short press red button to auto ignition
32. Then in “Flash” tab, put check mark only on :
- In Flash
- In Bcore
- Master codes
33. Click on “Do the Job”
34. Go to “Settings” tab and click on “Service Mode”
35. Short press red button to auto ignition
36. Go to “Various” tab (make sure IMEI is filled, if not click on “Read IMEI”)
37. Click on “Freeze” ---> Freeze (5) : It is executed
38. Switch off phone
39. Switch on phone
40. Switch off phone
41. Run WinSwup
42. Put check-mark on “Pre-Check” and “Post-Check”
43. Click “Start” and short press red button
44. Voila…WinSwup works fine….wait until finish.
Here are some log of PapuaUtils.
Re: M65 Firmware Update Problem
Postby REC*303 » July 19th, 2010, 4:15 pm
gak pernah mas...
cuma kalo update firmware pernah mengalami kendala pada C65 dimana firmware bawaannya sangat jadul dan full of bug...
Postby mamed_3279 » July 19th, 2010, 4:28 pm
pernah mas ngalamin begitu..solusinya saya kirim hpnya ke kang pintu :"> selesai dah.. :))
kabel data saya juga gitu,tapi di M65 atau M75 juga tetep aja kedeeksi dca-500..ga pernah jadi dca-510
Postby herry_potter » July 19th, 2010, 5:15 pm
Trims mas...untuk konfirmasinya...
Ternyata ada yang sama dengan masalah saya.
Kemarin-2 saya pikir PC di rumah yang problem.
Hari ini coba di PC kantor, sama juga.
Apa mungkin DCA-510 nya yang problem?
Tapi kok di M75 terdeteksi benar?!
Postby adrian vandenberg » July 19th, 2010, 6:08 pm
Seinget saya musti update bootcore atau upgrade secara bertingkat, dari 12 ke 50 agak terlalu jauh soalnya. CMIIW.
Postby gandalf » July 19th, 2010, 6:12 pm
udah dicoba di factory mode dulu mas ? CMIIW
kadang kendala tsb bisa terjadi krn hash nya FFFF
Postby herry_potter » July 19th, 2010, 6:46 pm
Mngkn juga krn jarak firmware terlalu jauh atau nanti saya coba cek HASH nya dan transf ke factory mode...
Postby herry_potter » July 19th, 2010, 9:28 pm
@mas Gandalf, betul mas! HASH nya error "FFFF..."
Ini hasil dari pembacaan GetCodes yang saya tanam via SiMoCo di M65 :
IMEI :
35366900501903
HASH :
FFFF-FFFF
FFFF-FFFF
FFFF-FFFF
FFFF-FFFF
ESN :
25A1-691A
Jadi HASH ini yang menghalangi firmware update!
Trus saya baca-2 posting lain "Tutorial: Mengatasi masalah HASH FFFFFF pd S75"
yang ditulis oleh mas Irfanics, dan ditulis ulang oleh mas Imoeng.
Ikuti step-stepnya...1 kali gagal...kedua kali gagal juga...
Kegagalannya karena waktu ada perintah Auto Ignition, saya tidak tekan tombol merah.
Sekali tekan tombol merah....tunggu sampai proses selesai, ditandai dengan
"Boot released. Everything is closed!"
Sekarang HASH nya menjadi :
5AC2-651F
DD31-2177
7A71-00CD
82C6-1C82
Cihuy! Security Mode : Factory Mode.
Siap update firmware dan dioprek!
Trims buat semua infonya...
Postby mamed_3279 » July 19th, 2010, 10:17 pm
mantaff juragan satu ini..kalo saya mah udah pening duluan :))
selamat yah mas :D
Postby Hendz » July 19th, 2010, 10:27 pm
Horeeeeeeeee,,, PredaTorz neva beaten by just "FFF" :))
