Siemens SXG75 - phone repair (Starter)
Postby ilham » July 24th, 2011, 2:51 am
Sumber: http://spssoftware.cz/?view=zabava/sxg75/opravasxg1
Mungkin software2nya sudah tidak update dan broken link, silahkan cari sendiri dulu (belum sempat cariin :D ), ambil tutornya saja.
Di thread ini sepertinya diperuntukkan SXG75 yang masih bisa tampil "download mode" alias bootcore untuk service mode masih bagus.
Here's published guidance on repair SXG75
! Before you begin the repair process carefully read this!
! Tested on eight phones!
Required Software: 3GswupFU, QPST, SXG75 Controller (BitPim). If you upgrade to a compatible yet FW26 FW Benq.
Install 3GswupFU, QPST, SXG Contrroller.
Factors to phone Test Mode
We will need this file. Download the file and copy to
C: \ Program Files \ Siemens \ 3GSwupFU \.
The file name, type your IMEI. IMEI can be found on the label under the battery all the way down the last line.
File name pattern 357250000123456.brt
IN THIS directory NV_EFS_Restore.exe run the program.
Switch the phone to download Mod. To do this, the phone is switched off and disconnected the cable. Hold down # and turn on the phone.
Display phone must show logo SIEMENS. Connect the cable to mobile and computer. The program set a number Diagnostic Port and click the Restore button.
Ignore this message. Sometimes Restore join up several tries. so patience
When complete, the phone restarts and boots up mode Factors Test Mode. Program continues once again the phone logs on to a computer.
If you have correctly named file should not be oběvit this message. If so then try to Restore. Up to 3 times then it is unnecessary repetition.
This is the successful completion of the renewal NVItem. When finished, restart the phone again and it should boot up.
To quit this program to any result and proceed to the next step
Restore files from backup to phone
Who was able to correctly restore a functional NVItem phone and do not perform these steps.
Who has the phone still in FTM to restore phone files from root.rar
Here is its ease of use provided SXG75 Controller
Other programs use QPST and BitPim
Files in ROOT, BREW \ BREW and CFG \ SHARED directory are necessary for the phone comes up.
These files must be copied to the phone.
!!!!!!!!!! Overwrite all files !!!!!!!!!!!
Other files that you delete them on the phone. They are not important and it will not affect anything.
Downloading Firmware 26 to phone
Start the original FW26.
Start recording by clicking on the START button.
After confirming the license conditions of the program requires connecting the phone to the cable.
Follow exactly the instructions of the program.
The program will inform you about recording.
When 65% of the phone restarts. Let him swell up and
!!!!! DO NOTHING AND WAIT !!!!!
Within moments, will continue recording.
After completion of 98% and we recorded the next reboot FW26.
Now you can exit the program.
QPST Software Download - restore NV Item
When you run Software Download of QPST program package.
c: \ Program Files \ QPST \ bin \ download.exe
Go to the Restore tab.
In-line Port select Browse button to the communications port.
Next, select the file QCN file sxg75.qcn
Check the option Allow phone / ESN Restore and click Start.
This has been achieved from the second time so do not panic!!
That did it certainly will.
The program can terminate.
customization phone
Run c: \ Program Files \ Siemens \ 3GSwupFU \ startup.exe
Important: Diphtheria only customization and click Continue. If you leave the selected software update phone firmware to play the 22nd
The program itself will find a phone and customization.
In the next window, you can track the progress of the operation.
After completion of the phone boots up and you can start making calls.
Re: Siemens SXG75 - phone repair (Starter)
Postby gandalf » July 24th, 2011, 9:54 am
ini bisa untuk hidupin sxg yg matot ? itu pas restor nv , tekan pagar dan on (nyala logo siemens) itu sbnarnya buat yg ga matot ?
Postby ilham » July 24th, 2011, 8:17 pm
Ada 2 sistem boot di sxg75, normal mode dan download mode.
Kalo normal mode ga bisa baru pakai download mode buat perbaiki.
CMIIW.
Postby vhatoy_vedder » July 25th, 2011, 12:22 am
mantab neh mas ilham emang...hehehehe....mmmm lagi penasaran install aplikasi brew..pernah nyoba install playex....icon dah tampil di app mgr....tp di klik error runtime....coba istall ulang lagi malah gak tampil sama sekali....n kebiasaan kalo coba install aplikasi brew menyebabkan tombol sortcut internet gak berfungsi...hmmmmmm :bingung:
vhatoy_vedder
Postby ilham » July 25th, 2011, 1:53 am
Saya belum pernah pegang sxg75 hidup2 :P , jadi ga bisa bicara banyak.
Baiknya permasalahannya dibuatkan trit sendiri saja mas Tio biar lebih fokus dan mengurangi budaya oot. :D
Postby vhatoy_vedder » July 27th, 2011, 11:06 am
maaf mas OOT ;)
vhatoy_vedder
Postby ilham » July 27th, 2011, 1:55 pm
Ga pa2 Mas, itu kan tandanya xper sejati, tapi jangan sering2, ntar jadi kayu jati, wkwkwk :D
Postby Budi_XP » August 18th, 2011, 3:26 pm
Wah kelihatannya dengan tutorial ini akan ada kebangkitan SXG75 Matot seperti yang telah diberitakan sebelumnya di ...... :)
Postby aradroben » November 24th, 2012, 9:24 am
punya ane waktu jalanin NV&EFS Restorer, muncul tulisan, IMEI takterdeteksi, padahal file brt nya dah ane ganti nomor sesuai di imei, knapa ya gan?? tw solusiny??
aradroben
Postby ilham » November 24th, 2012, 1:08 pm
aradroben wrote:punya ane waktu jalanin NV&EFS Restorer, muncul tulisan, IMEI takterdeteksi, padahal file brt nya dah ane ganti nomor sesuai di imei, knapa ya gan?? tw solusiny??
File template.brt-nya sudah dihapus?
Saya pribadi belum pernah pakai yang ini, thread ini hanya copy-paste saja dari site luar. Saya biasa pakai yang di sini: viewtopic.php?f=45&t=1624
Return to SXG75/SG75/EF81
