Sinyal & Batere g Cocok
Postby mBenQ » May 25th, 2010, 3:40 am
apply patch "extra Info (persen dan db)" & "Bluetiful (blue bar)"
check disot
mohon pencerahannya, mengapa kedua patch tesebut menampilkan info yang berbeda
Re: Sinyal & Batere g Cocok
Postby mamed_3279 » May 25th, 2010, 5:24 pm
mungkin emang maksudnya kaya gitu kali mas..dulu cx65 saya juga gitu :D
Postby mBenQ » May 26th, 2010, 8:00 am
mamed_3279 wrote:..dulu cx65 saya juga gitu :D
berarti sekarang g kan? gimana ceritanya?
Postby Hendz » May 26th, 2010, 11:28 am
Itu x65 apa x75 maz?
Postby mBenQ » May 26th, 2010, 12:00 pm
lha piye tho mase...
ini kamar x75 :D
Postby TUFF Stough » May 26th, 2010, 12:11 pm
MP ato elf?
Postby Hendz » May 26th, 2010, 1:25 pm
Hehehe abiz tampuilan skrinsyat na kek x65 :))
Postby mBenQ » May 26th, 2010, 7:19 pm
^^emang tampilannya cx75 gak jauh beda ma x65 ya
@tuff
g ngerti maksute bos :D :D :D
maklum...nyubi
Postby TUFF Stough » May 26th, 2010, 9:13 pm
AFAIK extra info ada 2 versi, Master Patch (yg dikontrol lewat midlet) dan elf (yg dikontrol lewat setting file bcfg). Coba aja jalankan midlet Master.jar, lihat ada ato nggak extra info-nya. Kalo ada dan aktif, tinggal di-non-aktifkan saja.
Postby mBenQ » May 27th, 2010, 12:07 am
maaf mas tuff saya masih kurang mudheng tentang afaik dkk karena saya blas g ngerti tentang patching. jadinya cuman nyoba kopas aja. mohon bimbingannya yah :"> :"> :">
berikut ini histori urutan Patch CX75v25 20100523
1. OD Forever
2. Call list saving
3. Card defect or not fotmatted
4. Extra info v3.0
5. GPRS Nokia
6. main screen changer 5483 (batal, habis net search lsg mati))
7. download zip
8. Change font size on MainScreen v2
9. BLUEtiful
10. bat & signal nokia
11. Calculator s75 (batal, habis net search lsg mati)
12. Vista menu (batal, habis net search lsg mati)
13. digital hour (batal, habis net search lsg mati)
14. disable aircraft check (batal, habis net search lsg mati)
15. developer menu (batal, habis net search lsg mati)
Return to CX75/M75
