Motorola SLVR L7, Z6 and other series.
Forum untuk membahas handphone merek lain (Nokia, Samsung, Sony Ericsson, dll)
Postby inoetea » March 31st, 2011, 8:54 am
XPiers yg budiman, mana tau ada yg tau link download software singkronisasi (backup ponbuk, backup SMS n etc u/ HP tsb diatas? Would be greatly appreciated :) Tengs berat. :)
Re: Motorola SLVR L7 & Z6
Postby adhyzip » March 31st, 2011, 9:40 am
biasanya mas hendz tau ni tentang moto
Postby adrian vandenberg » March 31st, 2011, 9:42 am
Ehem, gue ada MPC terbaru yang support kayaknya. Hmmm gmn ya? kalo di kirim via email guede banget keknya....
Postby Hendz » March 31st, 2011, 9:54 am
bro you can hav the, what we call it, an MPT (Moto Phone Tools) Original CDROM and then install it yerself, run it up and for the first time you gonna be asked for some database upgrades thru the net but you can skipped it out, so just go without upgrades alone then see if it is can work. and it should work. But if it doesnt, you really need to choose Upgrade then :) -- (there moto is always upgrade their tools according to all their mass product types). -- by this MPT you might also see other products etc, directly, and no need fox,ie,opera browsers etc :)
second is... you can use P2K-Tools 3 made by MMUS.us as I use it, got by here - http://www.mmus.us/forum//downloads.php?do=file&id=2005 (3.71 MB)
this utility has more rich featured no just for daily office tools like SMS, Phonebook & Datebook backup, yet also fo fw-backups (like FUBU), patching (like V_KLay) & flashing too (like SWUPs), and, can communicate in two 4-ways into all P2K-based phones like L7.
ok thats all i got :)
btw the EL-Seven is a very very great cheap jaduLer phones,,, for only Rp 250rb-- 300rb :))
but, u can make it up sophisticating (mod) thru here too (by Bang Jaim) - http://mmus.us/forum/showthread.php?s=5 ... f4&t=10382 - (no need to think, just plug it, flash it, have it, use it)
Postby inoetea » March 31st, 2011, 3:04 pm
@ mas Adhy: Iyo, Mas. Betul skali.
@ pak Guru: Hilang tanpa jejak, Bro. Ini buat Kakak yg slalu mntransfer sgala macam info yg masuk ke HPnya u/ ditransfer ke PC kantornya. Dah gak usah ribet, langsung kirim aja nanti ke alamat yg akan gue SMS or pm linknya barangkali? Tengs berat.
@ maz Hendz: Wow! Thanks you so much for the links.
Eniwe MPC official trbaru itu itu ver 5.0.5 apa bukan? Brapa MB/GB hanya u/ MPTnya aja? Bisa runing well di Windows 7 apa gak, yak? Tengkyu... :)
Postby Hendz » April 1st, 2011, 8:34 am
yg aq pk si di Windo XP, klo Windo 7 aq ga pny OS na malah :))
MPT kali tuch Maz? bkn MPC hehehe....... klo MPT yg aq pny versi 5.27, ga pernah aq upgrade lagi coz dah cukup penuhi kbutuhan Milestone, E6, E1, L7 ama Mba Fitri (V3i) pny q :D
--- lah mangna mazInoe ga pny CDROM asli MPT gt maz???
ide baguzna emang kudu nodonk mazAdrian Van Damme spy mao bakarin sidi MPT truz kirim hehehe,....
P2K-Tools yg aq sebutin diatas tu maz wajib dimilikin jg wat "moto-gangsters" :))
kan cuma 3.7 MB, bisa REG bentar jd member di MMUS.us - trz donlod - truz pergi lagi dah klo msh puyenk baca2 =))
lagian P2K-Tools jg dah integrated, hampir smua kbutuhan moto dia mampu, dari mulai edit phbook ampe nge-fles (kcuali bikin themez).
cuma enakna klo yg MPT bs lgsg cetiNk SMS, sama kyk prog Siemens SiMoCo.
MPT jg dilengkapin ma browser internal tp ngepLot khusus ke web Moto Inc. - klo P2KT lom mampu coz baru riliz 3
btw nich Driver na ke PC klo blom pnya --> http://www.4shared.com/file/NcBR-jCF/Mo ... _29__.html
ok maz, good luck with L7 ma Z6, pesan aq klo jg cinta mati ma tu barang, pliz beli KIPED ORI + BATRE ORI + CASING BESI na jg sbg cadangan wat jangka waktu lama, sama ky Siemens sndiri :)
Postby inoetea » April 1st, 2011, 5:18 pm
Hehehehe... Maklum gak pegang Moto, jdnya gak paham or ada salah nyebut istilah. Tp saya baca itu software suport Vista. Mungkin analisa saya cocok di Win7 coz platformnya gak beda jauh (i hope so spy masalah gak mlebar jd downgrade system :P ). Spt yg sudah saya katakan diatas, itu punya Kakak n CDna hilang tanpa jejak. Buat PSK, eh, apa itu namanya? P2K Tools, yak... Iya, itu tools emang udah diincer hari Sabtu (libur soalnya) mo di sedot. Eniwe tengs u/ link drivernya. Mantab...suport mulai XP sampai 7 kata yg pd komen. Kebetulan driver itu yg belum saya dpt. Part ori itu wajib, Mas. Inoetea anti pake part Moto non ori. Tangan langsung gatal2 klo pake Moto tp partnya non ori (nyontek kata2 pak Guru) :)) . Tengs banget, Maz Hendz. :)
Postby ilham » April 1st, 2011, 6:15 pm
Hehehe... *emotnyengir*
Postby Hendz » April 2nd, 2011, 3:41 am
Lagian SLVR L7 cm 250-300rb an ga rugi dikolexi coz bs mp3 video dg lcd 256rb warna 176x220 and bs di EDGE in :)
hmpir smua driver ma utility bs didpt di MMUS.us or modmymobile.com
Postby inoetea » April 6th, 2011, 8:15 pm
Bener, Mas. Eniwe makasih temans (special u/ mas Dany & maz Hendz) atas info & link yg udah di share. Beliau udah trsenyum kembali n bisa kerja maksimal lg dgn L7 & Z6nya. Cuma agak kaget aja dgn tampilan versi 5 yg trlihat berbeda dgn versi jadulnya yg hilang. Makasih berat, yak... Problm kelar scara trpelajar :)
Return to Handphone lain
