WTA Berapa Lama Charge IMS
Forum utk membahas tentang aksesoris HP, Handsfree, cover, keypad, battre, etc..
Postby Budi_XP » January 30th, 2011, 12:13 pm
Masih asing dengan IMS 700 nich berapa lama charge nya? dan pakai batre apa yang bagus :)
tolong di share ya :)
Re: WTA Berapa Lama Charge IMS
Postby adrian vandenberg » January 30th, 2011, 12:14 pm
IMS gak di charge, murni pake batere atau adaptor. Gak ada batere built in nya.
Postby adhyzip » January 30th, 2011, 12:29 pm
Loh katanya kmrn pk adaptor mas? Mungkin mksdnya m budi tu pake batere recharge itu mas?
Postby Budi_XP » January 30th, 2011, 12:57 pm
adhyzip wrote:Loh katanya kmrn pk adaptor mas? Mungkin mksdnya m budi tu pake batere recharge itu mas?
@Danny, Adhy: Ya benar Mas, batre recharge :) itu ada fungsinya kan?
Postby adhyzip » January 30th, 2011, 1:02 pm
Brarti mase pk batere bkn adaptor tho? Kalo batere recharge menurutku trgntung batere ma chargernya, tapi walo kpasitas besarpun tetep tiap charge pasti menurun..lbh enak pake batere sekali pakai tp yg alkaline.lbh stabil ouputnya..sm ky mic wireles mending pk batere baru tiap dipake drpd btre recharge..lbh enak lg pk adptor hehe
Postby herry_potter » January 30th, 2011, 7:14 pm
sy pake sony nimh 2300mAh rechargeable, charging 8-10 jam, stlh lampu indikator charger mati biarkan 1 jam spy full...ngirit batere..
Postby Esant84 » January 30th, 2011, 7:31 pm
pake aki kering yang biasa buat lampu emergency keknya mantep tuh,seandainya dayany 6volt 5Ah jadinya 5000mAh
IMS voltagenya berapaan yak?
Postby herry_potter » January 30th, 2011, 7:57 pm
kalo 1 batere 1.5volt maka 4 x 1.5volt = 6volt
Postby ilham » January 31st, 2011, 1:53 am
Ada juga charger buat alkaline di www.jakartanotebook.com ... (bukan promosi :D )
Postby Hendz » February 27th, 2011, 6:22 am
wat info aja:
nich baru kmaren w slsai bikinin CHARGER (bkn adaptor) wat bozz PinturicchiO.
so, emang bkn adaptor yg dipake tp charger 6,6V 1A, truz kudu pk batre rechargeable (Li or NiMH) 4x 1.5V 1A
soalna klo cm pake batre biasa kek ABC gt, chargerna jd ga fungsi, so klo abiz y buang ae...
sygna IMS700 cm pk spiker keciL & magnet keciL 2". sygna jg IMS700 ga kompatibL ama sluruh hp Siemens dg lumberg tipiz (misal: dia ga bs dipake ama SexyOne). tp kualitas audiona lmyan lah pd masanya, cm jgn kenceng2 setel muzik.
lama chargingna gatau, trgntung arus (Ampere) batre yg dipake.
lagian nich cm skedar wat test charger, so batrena ga dicharge pe penuh
--thatz all
Return to Accesories Siemens
