THE U10 & U15 FIRMWAREZ
Postby Hendz » February 1st, 2012, 7:56 am
(Discussing in this thread is continuation from a "wrong place" previously at http://siemensxp.com/viewtopic.php?f=6 ... =70#p26631)
Well it seems like full Firmware you got, with Russifikatsiya on it. I will inspect them one by one later on.
Here's ma reports for the moment:
1. The U15_Russification is an SHX file, a Motorola-style that contains Languagepack in Russkie which the only RSDLite program or Flash&Backup program that can open it. It's okay I got those programs on my disk already -- BUT I failed to extract it as my 7z says "Unsupported compression method" -- Can you fix it or replace with new one?
2. The U10.7z contains Update Software packed in RAR, and it looks okay
3. Now I'm wating for U15_disc.7z, it's a big file of 278 MB in size, takes about a hour or more... quiet huge for such phone on that age :D ... My best guess it's kinda WHOLE FUBU of U15 itself.
Well I'll see what I can do with those files. So I tell ya later............................... spasibo druyg
Re: U10 & U15 FIRMWAREZ
Postby Hendz » February 1st, 2012, 8:02 am
Okay this is my next progress...
1. The "U15_disc" is on his way to my disk
2. The U15_Russifikatsiya is okay now as I replaced my 7z with of 9.20 version. So the file is really ready to be flashed-in as a Russian Languagepack only
3. Apparently the U10.7z which containing two PST (Product Support Tools) v6.1.9 are obsolete now. It even can't run properly under Windows that already has Service Pack installed like mine. The program need a Windows that doesn't have Service Pack such as Win98 or Win2000).... So I decided maself to try the latest new of PST (version 7.2.5 General) (13 MB). You can download it from one of these URLs if you wish:
- http://hacktherazr.com/downloads.html (for tools of almost all Moto old-fashioned systems)
- http://www.4shared.com/file/5772601/f76 ... 5.html?s=1
- http://www.mediafire.com/?byybsxmwj1k (direct download)
The PST 7.2.5 have more advanced functions than the previous one and I believe it would help you much of anything, including upgrade/flash back the FW on those Siemens U10 nor U15. And by installing PST 7.2.5 you could have key-features like this:
So the "U15_disc.7z " is at my disk now (291.5 MB). It contains "031021_1002.mds" and "031021_1002.mdf".
But the only thing I don't understand is how to open or use those files. - Do you have any idea?
I hope that would be enuf for now in assistin' about the twin-remarkable Siemens U10 and the U15, which was in-cooperation with Motorola of that time ever :) -- I personally gladly to do that.
Anyway, ma goal is so simple:: I still need to know how to CRACK the original Firmware of both phones, so we can "play" almost everythin inside to get MAX performance as much as it can :D That's all....
Re: THE U10 & U15 FIRMWAREZ
Postby ilham » February 1st, 2012, 10:00 am
7z opened by 7z application: http://www.7-zip.org/
Winrar sometime can not open it.
Postby TUFF Stough » February 1st, 2012, 10:30 am
I believe what Hendz means is how to open the mdf and mds files.
Postby ilham » February 1st, 2012, 11:16 am
mdf? Hmmm, sound like image file of Alcohol120 extention..
Postby ilham » February 1st, 2012, 11:19 am
Download here and mount .mdf as a drive.
Postby Hendz » February 1st, 2012, 3:08 pm
>> @Mr.iLham - Right, the Seven-Zee is last generation of high-end Packerz used by Linux and Windows, Freeware, and sometimes needed to pack an .MPKG (linux mobile apps) too. I got the older version one of long time ago, and I renewed it again (v9.20) thru that URL to open the Languagepack file and it succeeded.
>> @Mr.TUFF - Yea it's all about how to open the MDF+MDS files given by our Komrad Святослав.
I thought it should be of uhmmm.... an SHX or SBF (the P2K Superfile / FLASH of Moto's Environment) which similar to Siemens FUBU.... but I'm wrong, I didnt even see any of them on those given files :( :(
>> Did our Komrad mis-sending those files??? or... Both U10 + U15 are really really use those fileformat on their system???
>> And last time I checked, the http://www.alcohol-soft.com/ offers us about CD & DVD Burnin' ... and is nothin about "How To Open/Extract/Parsing etc The FUBU" anyway ...... :)
Well I guess Святослав should've known well what's the proper program for this purpose.
_________________________________
Send from Milestone using Tapatalk
Postby ilham » February 1st, 2012, 3:49 pm
Hoah... i mean:
Mas, itu file extensi .mdf adalah image file dari cd/dvd, bisa dimounting salah satunya pake aplikasi alcohol120%.. download di sini, install, lalu mount file MDF tadi sebagai virtualCD pake aplikasi alkohol itu..
Awas jgn bnyk2.. :P
Postby ilham » February 1st, 2012, 3:51 pm
Jadinya ntar ada virtualCD yang isinya file2 CD U15.
Biasanya org pakai .ISO, .MDF biasanya buat CD yg terproteksi.
Postby Hendz » February 1st, 2012, 3:52 pm
^^^ oh gt? :)) kirain FUBU U15 =)) ..... ok i'm on ma way later....
