Software V_Klay
Software V_Klay
Postby ilham » December 12th, 2010, 12:26 am
* Sebelum memulai menggunakan VKlay dimohon agar membaca "PENTING: BACA INI SEBELUM MEMULAI FLASHING & PATCHING !!" terlebih dahulu.
* Untuk mempelajari lebih jauh tentang pathing (.vkd) di VKlay silahkan baca di : TUT ● Tab "Patches" di V_KLay.
* Sumber : http://www.vi-soft.com.ua/index_e.htm
POST asli di bawah ini dari RumahLama oleh Om Qunto ; edited by Me ; Makasih buat PINTURICCHIO buat backupannya ;)
V_KLay - for patching, flashing and changing keyboard layout
V_Klay terbaru v3.3 update 28 June 2005
Download here: V_Klay v3.3 ~ 1.7 MB
WARNING! for х65 series: if you use loader, what is generated by other program, check that parameter "optAuthorization = 1" (without quotes) in section [PhoneCommonInfo] is exist in that loader. The .vkd file of loader you can open with help of any text editor, for ex. "Notepad".
List of supported phones in this version:
Siemens 1168, 2118, 2128, 3118, 3618, 6618, 6688, A35, A36, A40, A50, A52, A55, A60, C30, C35, C45, C55, C60, M35, M50, M55, MC60, ME45, MT50, S35, S40, S45, S55, SL42, SL45, SL55, SX1, CF62, A65, C65, CX65, M65, S65, SL65.
(Password boot) - connecting, using bootkey. Bootkey is unique for each phone. Bootkey of your phone must be writen in the loader (x65.vkd, open it as text file). You can calculate bootkey of your phone for ex. by program x65PapuaUtils. Or, more simple, with help of V_Code2VKD, witch, by default assigned on last (rightmost) button of external programs of V_KLay - just connect phone, select COM port, baud rate, press the button, the follow onscreen guides... After this use loader with ...(Password Boot), more info.
(Chaos BootPatch) - connecting to phone with bootcore that is patched by midlet-patcher from Chaos px65v3.zip (more info). This method is obsolete, use (Password boot).
(Bootcore bug) - connecting to the phone, using bootcore bug.
(Patched bootcore) - connecting to the phone with patched bootcore.
(Test point) - (use it for x52 and older) - with test point - mean, that this driver for phone, in which test point connected to the ground. More you can read here (russian).
(online) - meah, that this driver for flashing the phones while it is on (normal working of phone). For use this driver in the SL45i you need to apply a patch from Mamaich (download it from here or from site of author).
Creation of the .vkp files of patches:
SLFC from Chaos - download
For Windows, with console interface. Compares 2 files (fullflash). The result you can save in .vkp file.
FFPatch from Alexsandr Yablochkin - download
For Windows. Compares 2 files (fullflash). The result you can save in .vkp file. Also this program can search what patches is applied to the file with fullflash.
FullFlashComparer v2 from SHPION - download
For Windows. Compares 2 files (fullflash). The result you can see in a edit box, then you may save it in .vkp file.
FilesComparer v1.2 from SaiNT - download, from author's site
For DOS. Compares 2 files (fullflash).
Hex2VKP v0.1a от Redkin - download, from author's site
For Windows, with console interface. Intel .Hex to VKlay .VKP Converter.
Downloading old versions of V_KLay:
V_KLay v2.7.2 - скачать
V_KLay v2.5 - download
V_KLay v2.1.5.2 (english) - download
update to V_KLay v2.1.12 - download
All archives you may open with WinRar version 3.0 or higher.
Before first applying the patch you must read full flash of the phone (make a fullflash backup). Saved full flash may be necessary in process of repairing of the phone.
All programs and files from this site is STRICTLY FORBIDDEN to use in commercial objectives!
Authors do not suffer any responsibility for possible damage put by use of all that is on this page.
All that is on this page it is given AS IS.
Re: Software V_Klay
Postby Hendz » December 12th, 2010, 3:59 am
ko yg diatas ntu msh ada tulisa "skachat" maz? ... gnti aj ma download coz artina sama :))
Re: Software V_Klay
Postby ilham » December 12th, 2010, 7:18 am
Dikutip asli dari situsnya, maksudnya mungkin bahwa hasil downloadnya nanti berbahasa russian.
Re: Software V_Klay
Postby Hendz » December 12th, 2010, 7:06 pm
yah tp kan udah diadapt ke inggris jd ga boleh ada kata SKACHAT (скачать) lagi hehehe.......
lagian lgsg aja arahin ke V_KLay 3 ajah coz versi lama udah obsolete
Re: Software V_Klay
Postby ilham » December 12th, 2010, 7:21 pm
Hendz wrote:yah tp kan udah diadapt ke inggris jd ga boleh ada kata SKACHAT (скачать) lagi hehehe.......
Yang adapt siapa? Dari http://www.vi-soft.com.ua/index_e.htm -nya sudah inggris... :))
Hendz wrote:lagian lgsg aja arahin ke V_KLay 3 ajah coz versi lama udah obsolete
Siapa tahu masih ada yang butuh... ;;)
Re: Software V_Klay
Postby Hendz » December 12th, 2010, 7:50 pm
oh jadi si Oom Valery dah nginggrisin dulu y?
tapi ga maz, ga akan ada yg butuh versi jadul dibwah 3.0 :P yakinlah dah sumpah :))
