usul link download firmware
Tiada orang yg sempurna! kami menerima segala kritik, saran, dan komentar rekan-rekan demi memajukan forum ini.
Postby vhatoy_vedder » January 19th, 2012, 3:16 am
mau usul ajah neh....kasih link / sub forum buat firmware donk....kayak di siemensmania.....makasih..test test test :D :D :D :x
vhatoy_vedder
Re: usul link download firmware
Postby ilham » January 19th, 2012, 3:26 am
Usul di terima. Terima kasih sudah menghubungi kami.
Tulalit tulalit tulalit... :D
Postby ilham » January 24th, 2012, 1:32 pm
Ada yang bisa kasih saran untuk edit webnya?
Postby Святослав » January 24th, 2012, 5:44 pm
vhatoy_vedder wrote:kayak
ilham wrote:Ada yang bisa kasih saran untuk edit webnya?
Edit HTML and CSS?
http://www.htmlvalidator.com/
Comfortly edition of tags.
Try free version.
CF-P2 M7 U15x2 C30 S40 K45P S46 SX45i S55_GoldenStatue SX66 C75_White CC75x2 FE75 SXG75 etc.
Past: SX1 Carbon, X1, X3, S10 BMW Limited, SL10, S15, U15x5, M65 Rescue x3, SF65, SK65x2, CX70 Emoty, CXT70, EF71x2, E72, SG75, SXG75_White, M7x2 etc.
Святослав
Postby ilham » January 24th, 2012, 5:51 pm
Ok, thanks, i will try to learn. ;)
Postby Святослав » January 24th, 2012, 6:44 pm
Святослав
Postby ilham » January 24th, 2012, 11:31 pm
I have no knowledge about web editing, i confuse with htmlvalidator :-/ , i will ask my friend for this.. :D
Thanks Mr... ;;)
Postby Святослав » January 25th, 2012, 1:16 am
o_O
You are admin! How you was make The Site?
Святослав
Postby ilham » January 25th, 2012, 2:01 am
I am not the real admin, mr. Gandalf does..
Besides, to make this site from PHPBB templates is not too difficult.
For this thread is not difficult to make the thread for firmware download links, i just want to edit front of board (php) to make it more function.
Postby Hendz » January 27th, 2012, 1:01 pm
HTML-validators got notin to do with WEB-related scripts such as HTML itself nor PHP/mySQL. Validators intended only to see whether a directive/function within a Tag had properly written according to markup-lang conventions.
And in this case, someone need to just add/edit PHP section which deeply lies in the front page of the forum.
Bottom line is that it can be simply figured out this way:
1. Provide a free-domain like http://abcd.com
2. Give a link to the users like for example: <a href="http://abcd.com/downloads/index.php">Download</a>
(where the index.php [or even just a simple index.html] mostly acts as a download area for all files needed)
The abcd.com can be one of most famous zone like "www.4shared.com" which is easily can be uploaded/downloaded at anytime
Hope that helps...
Return to Pengumuman, Kritik, Saran, dan Komentar
