SXG75ekspi
SXG75ekspi
Postby ilham » July 4th, 2012, 1:17 am
Screenshot #1:
Image__Image__Image
Screenshot #2:
Image__Image__Image
Screenshot #3:
Image__Image__Image
Screenshot #4:
Image__Image__Image
0. Download SXG75ekspi.zip (Signature 09.09.2013), dan extract.
1. Backup data-data HP.
2. Apply FW 26, tunggu 10 menit sampai index mmc selesai.
2. Ubah ESN (aktifkan).
3. Ubah NV item:
Number Name (Desc) ---> Action.
2830 upload media enabled Album (activated media album), ---> default value=0 changed to=1.
2832 upload media postcard menu enabled (activated postcards), ---> default value=0 changed to=1.
2985 PU prompt enabled (Disable aero check), default value=1 ---> changed to=0.
3006 MS SMS Max number of SMS (limit on the total number of SMS messages stored in the phone), ---> default value=500 changed to=1000.
3015 poc PT show menu (activate the PTT setup menu), ---> default value=0 changed to=1.
3028 IM show menu (displays the menu IM), ---> default value=0 changed to=1.
3169 Browser show info session (Not seeing "info session" internal data browser), ---> default value=1 changed to=0.
3322 browser prompt exit (Removal of internal issues to close the browser), ---> default value=1 changed to=0.
3323 Force On Power Up (Disable battery check), ---> default value=0 changed to=1.
3393 PB default sorting (Contacts in the directory are sorted by last name, but according to Name), ---> default value=1 changed to=0.
3442 home screen enabled (Activating the "orange bar" on the main screen), ---> default value=0 changed to=1.
3460 show java enabled (Enabling Java image every time you start the java application), ---> default value=0 changed to=1.
4. Install aplikasi java dan theme dari folder "java&theme", lalu restart HP.
9. Buat folder "mp3" dan "videos" (huruf kecil semua) di kartu memori. (Lokasi standar untuk playex & videoplayex)
5. Copy dan replace folder "brew" di PC ke folder brew di HP dengan BMC.
6. Copy file brew\mod\ucweb\ucweb.mod di PC ke HP dengan BitPim.
7. Copy file brew\mod\dll_swflink\dll_swflink.mod di PC ke HP dengan BitPim.
8. Copy file brew\mod\BNIcq\BNIcq.mod di PC ke HP dengan BitPim.
6. Restart HP.
7. Full access to the filesystem of the phone's Java app:
Full access to the filesystem of the phone's Java applications reported Dimanest
You can open the file system by creating a program's EFS Explorer (included in QPST) in the folder brew \ shared at proavoy mouse button - New - Link ... the top of the pop-up menu to write something like / brew / shared / root (instead of root you can phone, or something like that) and click OK. After that, the phone appear in the folder that contains the root in the root directory of all the folders.
8. Hapus file-file yang tidak perlu:
- Hapus folder-folder language (selain EN dan common) di semua subfolder brew\mod\(aplikasi)\res\
- Hapus T9 selain En dan Common di folder ? (lupa :D )
- Uninstall theme-theme selain VistaMod2.
- Uninstall java app dan games yang tidak perlu.
- Hapus file-file gambar, audio, video di memori telp.
9. Apply theme VistaMod2 dan refresh java app dan java game di popup menu "startmenu".
Garis besar sudah tercantum semua...
Tulisan yang dibold = yang penting-penting, selain itu cuma disarankan. :D
Detail pemakaian, penjelasan, dan penyetingan nyusul. :D
Bagi yang sudah menerapkan SXG75xp dengan sig kadaluarsa -- dapat replace file-file .sig yang ada di HP dengan file ini: http://dl.siemensxp.com/XPed/SXG75/mod.zip (timpa folder mod di HP dengan folder mod yang ada di file tersebut dengan BMC)
Reason: Signature expired
Re: SXG75ekspi
Postby irfanics » July 4th, 2012, 5:48 am
pertamax setelah sekian lama
mantaf mas tutornya...
Re: SXG75ekspi
Postby Budi_XP » July 4th, 2012, 7:37 am
Inilah janji Mas Ilham, Trust admin hehehe
Wah ini sudah FW. 26 ya punya saya masih 22 bukannya stabil 22 Mas?
bisa minta id dan pass 4shared nya nich ;)
Re: SXG75ekspi
Postby Boowin » July 4th, 2012, 8:39 am
pengen coba tp gak punya sxg75
Re: SXG75ekspi
Postby jaketmerah » July 4th, 2012, 9:48 am
Beli donk mas hehe
Re: SXG75ekspi
Postby ilham » July 4th, 2012, 11:09 am
@BudiXP: 4shared link di atas tidak dipassword Mas.
@Irfanics: Saya juga sudah lama tidak buat thread. :D
Re: SXG75ekspi
Postby vhatoy_vedder » July 5th, 2012, 1:00 am
hadiirrr =D>
vhatoy_vedder
Re: SXG75ekspi
Postby ilham » July 5th, 2012, 5:29 am
Biasanya file yang lain di 4shared langsung bisa didownload, yang ini kok minta login dulu.? Tadi saya utakatik opsi di 4sharednya dan harusnya udah bisa download normal tapi kok masih belum ngaruh ya?
Indowebster lagi error untuk aploadnya.
Re: SXG75ekspi
Postby Budi_XP » July 5th, 2012, 5:38 am
Wah pada error ya Mas :), Semangat-semangat
Thanks Mas ini sudah bisa :D ganti lepi hehehe tambah orange menu mantabs Mas:)
Re: SXG75ekspi
Postby Esant84 » July 5th, 2012, 7:16 am
gak punya sy,gak bisa coment
