XPERIA-ish
XPERIA-ish
Postby ilham » May 2nd, 2011, 11:08 pm
POST asli oleh Benji (31st Desember 2008, 09:54), sedikit edit oleh saya ; Makasih buat PINTURICCHIO buat backupannya ;)
Benji wrote:
Dah lama ga oprek, ditambah kesibukan dan jujur aja dah mulai agak lupa prosesnya sampe kudu baca balik lagi tutorial.
langsung aja, berikut capture-nya:
(!) CX75v25 lg03
List patch+elf :
A. Main
01. ELFpack 2.3 24bit - Library SWI 80623
02. Cut heap
03. APIv14 (x65v100)
04. Master patch v14
05. Mainscreen dispatcher v3.1
06. Pictures add-on v5.1
07. Function library 70424
B. MP
01. Missed Events Indicator v2.1
02. MainScreen Changer v1.1
C. Standard
01. Call list saving when SIM is changed
02. Change disk names in menu
03. Disk selection menu
04. Disable
05. Enable built-In WV-client (ICQ AIM)
06. Enable Band Selection
07. Enable Developer Menu
08. Jpeg-compression with maximal quality
09. Setup illumination by 5%
10. Read message when key locked
11. Password protection some functions
12. Run Refresher on exit from Master-Midlet
13. Open Disks forever
14. Open closed EEPRom blocks
15. Show File Extensions in Card-Explorer
16. Vibra logo on MainScreen
17. Remove some language from input languages menu
18. Remove soft-keys from MainScreen
19. Remove Icons White Background in Native Menu
20. Change progressbar color
D. Graphic
01. Graphic volume indicator for MP3
02. WinVista style player volume indicator
03. Main menu list with icon
E. Font
01. Tahoma bold
F. ELF
01. sMenu (enable: right softkey)
02. FastRun (enable: ptt side key)
03. TurnOff (enable: camera side key)
04. XTask (enable: internet key)
05. ExtraInfo
06. ExtD
07. Clock
01. seperti yg telah diinfokan mas joy, patch grafis konflik di firmware 25 lg07 jadi sebaiknya gunakan firmware 25 lg03.
02. sebelum apply patch di atas, cek dulu apakah ada yg konflik mengingat patch dah di-compile.
klo ga ada konflik bs langsung di-apply dan copy file pendukung sesuai posisinya.
Download xperia-ish+mei-net (1,65MB). <-- Thanks 2 mr. Fish 4 backup file. :)
;-------------------------------------------------------- end --------------------------------------------------------
(!) S75v52
List patch+elf :
A. Main
01. ELF loader 2.3 24bit
02. Function library 81114
03. Master patch v14
04. Cut heap
05. API 70821 (x75v100)
07. Mainscreen dispatcher v6
B. MP
01. Date at the top of mainscreen as "Thu, 20 Apr"
02. Screensaver & Mainscreen dispatcher
03. MS position Net & Battery
C. Standard
01. Speedup of mobile till 208 MHz
02. Disable
03. Don't display central navigation key icon
04. Little sms report
05. Java Acceleration
06. OpenHiddenEEPROM
07. Rename files with extensions
08. Enable Band Selection
09. Keypad Acceleration
10. Smooth keypad light
11. Setup illumination by 5%
12. Increase speed of USSD-messages
13. Don't draw canvas in left bottom corner
14. Photos with maximal quality
16. Send Java and Any Files via Bluetooth
17. Call list saving when SIM is changed
18. Higher MMI Prio
19. Popups settings in SMS
20. Show to on create sms
21. Remove soft-keys from MainScreen
22. Do not show missed events on main screen
23. Disable icons of missed events
24. Run Refresher on exit from Master-Midlet
25. Extended attributes of MP3 and AAC-files
26. Do not show provider, profile and network search message on main screen
27. Invert digiclock ScreenSaver
28. Remove Icons White Background in Native Menu
29. Work without SIM card
30. Change dialing ringtone "No Connection"
31. Disable MediaPlayer DataBase Refresh
D. Font
01. Tahoma
E. ELF
02. FastRun (enable: left softkey longpress)
03. TurnOff (enable: vol - key)
05. Menu
06. ExtD
07. Aclock
08. ExtraInfo
09. eMenu mod
01. beberapa aplikasi java (master patch, dictionary, opera) dan elf (mc) tidak ikut disertakan.
02. bagi yg sudah menggunakan kompilasi mas qunto, tinggal apply patch mainscreen positioning dan ms position versi MP (02.vkp) dan update library.
03. asosiasi aplikasi menu di ELF:
FastRun
01.png -> Alarm
02.png -> Task
03.png -> Menu (ELF)
04.png -> Contact
05.png -> Profile
Eksekusi file tekan tombol 5
Menu
Organizer -> Notes
Internet -> Opera
Multimedia -> Media Player
Tools -> Pandemonium2
My Stuff -> My Stuff
Settings -> CfgEdit
Messaging -> Inbox
Programs -> Applications
Games -> Games
04. aplikasi opera yg dipakai disini masih versi 4.1.11355, silahkan edit dgn notepad/wordpad pada ELF sMenu (main.mnu) dan Menu (menu.cfg) jika menggunakan versi terbaru.
05. pada elf eMenu mod diberi kontrol pin (000000) pd menu messaging sebagai contoh penggunaan, pengaturan bisa dilakukan di eMenu Mod.bcfg.
pada dasarnya penggunaan elf ini sama seperti saat mengakses main menu standar, kelebihannya pada masing-masing menu bisa diberi pin control, pengaturan animasi menu, dsb.
Kekurangan:
01. Counter missed event indicator dgn elf ExtraInfo hanya menghitung miss called sedangkan sms dan task/appointment ga di-counter (penggunaan missed event hanya counter berupa text tanpa image).
Sebagai alternatif bisa menggunakan indikator yg sama tanpa counter, jadi yg muncul hanya image dari missed event (call, sms, task/appointment). pengaturan bisa dilakukan di elf ExtraInfo sub Missed Event.
02. Efek transparan dan color control pada themes menyulitkan u/ membaca (hanya) pada saat search file.
misal: jika di phone book kita search contact huruf G yg kebetulan ada 10 nama, maka akan dirasakan kesulitan u/ membacanya karena font yg dikontrol dgn efek transparan jadi tumpang tindih ga karuan, selebihnya ga ada masalah.
(!) koreksi :
01. patch mainscreen positioning ketukar file-nya. kelirunya di date/time, berikut yg benar :
;without Provider-Logo:
042E978: 0B 07 ;yy ;Date/Time ;don't works on skin application image
;with Provider-Logo:
042E9D8: 0B 07 ;yy Date/Time ;don't works on skin application image
+0
02. hapus asosiasi image jad dan jar pada extension.cfg (4:\ZBin\etc). baru nyadar td pas akses file java selalu bip.
Download xperia_S75v52. <-- Thanks 2 mr. Fish 4 backup file. :)
Download xperia_S75v52. <-- Thanks 2 mr. Dauz 4 backup file. :)
silahkan report jika ada permasalahan yg dialami :">
Reason: update link
Re: XPERIA-ish
Postby Budi_XP » May 10th, 2011, 8:36 am
Cakep nich dipasang di S75 kathie :)
Re: XPERIA-ish
Postby ahmad » January 17th, 2013, 1:29 pm
linknya g bisa dbuka,,tolong apa ada yg pnya link alternatif? atau barangkali ada yg punya filenya?
sekalian tutorialnya jg ya soalnya sy g paham cara pakainya. thx
ahmad
Re: XPERIA-ish
Postby ilham » January 17th, 2013, 3:08 pm
Site MadFish sudah setahun ini down, nanti saya coba cek backup punya saya, atau ada XPer lain yang mau memberikan? Di download center SiemensXP tidak ada filenya?
Re: XPERIA-ish
Postby ahmad » January 17th, 2013, 4:53 pm
ilham wrote:Site MadFish sudah setahun ini down, nanti saya coba cek backup punya saya, atau ada XPer lain yang mau memberikan? Di download center SiemensXP tidak ada filenya?
donlot center jg g ada,,helllppp
ahmad
Re: XPERIA-ish
Postby ilham » January 17th, 2013, 7:24 pm
Post pertama sudah saya update, untuk link download S75nya saya belum betulkan karena filenya belum ketemu.
Ada rekan-rekan yang bisa upload filenya?
Re: XPERIA-ish
Postby ahmad » January 17th, 2013, 8:23 pm
ilham wrote:Post pertama sudah saya update, untuk link download S75nya saya belum betulkan karena filenya belum ketemu.
sekalian step by stepnya gmn mas/tutorialnya ya hehehe,,,,
ahmad
Re: XPERIA-ish
Postby ilham » January 17th, 2013, 9:33 pm
Coba dibaca-baca dulu bagian FAQ dan Tutorial, Mas.
Saya sedang pakai HP sekarang, sulit untuk menjelaskan. :)
Re: XPERIA-ish
Postby ahmad » January 17th, 2013, 10:15 pm
g paham mas,g ada sepertinya titor buat yg ini
ya klo sempat tolong dbantu tutornya mas hehe,,
nunggu smpeyan ada waktu aja
atau barangkali tmn2 ada yg mau bntu tutornya?
ahmad
Re: XPERIA-ish
Postby ilham » January 17th, 2013, 11:00 pm
Ckckck, dopos mulu nih Ahmad, ngejar rating ya? :))
