M75@CX75 FW 25 - Satin
Postby andRa4 » December 15th, 2010, 5:24 pm
For M75 user who want to apply this PatchPack, please convert first your M75 to Cx75 FW25.
Instructions, can be seen in the thread Tutorial: Cara merubah tipe Product HP & Crossgrade
For the first time you want to apply this PatchPack, try to apply ONLY "Main Patches" (01 'til 7). Then try Turn the phone.
- If your phone does not want to be turned on, then "Undo Patch" all the patches before, because it means the phone needs to UPGRADE BOOTCORE. Instructions, can be seen in the thread Tutorial: Update Bootcore dgn PapuaUtils
------------------- Main+Master Patches -----------------
1. ELFpack 2.3
2. Cut heap
3. API
4. Master-patch
5. Mainscreen-dispatcher
6. Pictures add-on
7. Function Library
------------------ Independent Patches -----------------
1. Call list saving when SIM is changed
2. Change disk names in menu
3. Disk selection menu
4. Disable Message
5. Enable Band Selection
6. Enable Developer Menu
7. Auto Keylock Time
8. Allow KeyBoard Unlock by Double-Press of #
9. Smooth illumination turn-on
10. Smooth scrolling of long names
11. Remove Provider Name in ScreenSaver
12. Jpeg-compression with maximal quality
13. Setup illumination by 5%
14. Run Refresher on exit from Master-Midlet
15. Open Disks forever
16. Open closed EEPRom blocks
17. Show File Extensions in Card-Explorer
18. Show Hidden Files In Card-Explorer By Default
19. Vibra logo on MainScreen
20. Remove soft-keys from MainScreen
21. Remove Icons White Background in Native Menu
22. Change progressbar color
23. Remove "Help" Item from Card-Explorer
24. Remove comma between name and surname in Addressbook
25. Remove Confirmation at Inclusion of Loud Connection
26. No Start Sound in Video Rec
27. MegaLoudness
28. Java Acceleration
29. Keypad Acceleration
30. MainScreen Changer
31. Tahoma font
32. MMC/SD/SDHC 4GB Card Support
Download:
All patches & Supporting files: M75@CX75 FW 25 - Satin
This is an experimental project, if there is a bug please report it to me at this thread. Let me fix it. Thanks before,. :x
UPDATE 02012011
- SMS emoticon (Fix Animation on write new sms).
- New and add some icon at submenu native menu, my stuff.
- New graphic dekstop: batt wit red indicator when low bat.
- And many more.
I hope you will enjoy this tuning.
Re: M75@CX75 FW 25 - Satin
Postby ilham » December 15th, 2010, 5:42 pm
Nanya Pak Guru..:
Patch-patch ini berlaku juga ya untuk CX75 (Bukan crossgrade)? Soalnya CX75 saya elfpacknya rada tidak stabil (kadang-kadang buzz), bisa khan dipasang yang ini?
TQ. :)
Postby andRa4 » December 15th, 2010, 5:45 pm
ilham wrote:Nanya Pak Guru..:
TQ. :)
Bisa mas. Asal CX75-ny FW25. :D
Postby Budi_XP » December 15th, 2010, 7:43 pm
Dah bisa baca SIM card lagi Ndra M75 nya :)
Postby andRa4 » December 15th, 2010, 8:45 pm
budi = dah bisa mas.
kmaren dah saya bongkar lagi.
Postby Budi_XP » December 17th, 2010, 1:47 pm
Kalo patch buat M75 untuk menampilkan grafik equalizer pada Music player dan merubah analog clock biar lebih bagus apa ya?
Postby Hendz » December 17th, 2010, 2:24 pm
URL: patches.kibab.com/patches/index.php5?ph_model=20&ph_sw=74&action=disp_patches&pt[]=1&pt[]=2&pt[]=3&pt[]=4
DOWNLOADS: http://patches.kibab.com/patches/dn.php ... del=M75v25
Postby ilham » December 17th, 2010, 8:35 pm
andRa4 wrote:For the first time you want to apply this PatchPack, try to apply ONLY "Main Patches" (01 'til 7). Then try Turn the phone.
Bagaimana mau pasang "Main Patches"-nya dulu?, sedangkan file patch dari isi file yang diupload tergabung dalam satu file VKP (M75@CX75 FW25 Satin - Patches.vkp)??? :))
Tidak ada jurang pemisah antara Main Patch dan Independence patch... :D
Postby benji » December 17th, 2010, 11:18 pm
Supaya praktis mas, jadinya di-bundle dalam satu patch saja.
Tinggal liat aja list patch nya (1-7) sisanya dihapus dulu dan coba apply.
Saran untuk upgrade bootcore sifatnya tidak mutlak, hanya kasus tertentu saja.
a. Biasanya hp yg diproduksi awal dan versi bootcore tidak ada, untuk pastinya cek versi bootcore di papuautils.
b. Patch yg sama di-apply ke hp lain bisa tp di hp sendiri tdk bisa.
c. Ingat!, hati-hati bermain dgn bootcore.
benji
Postby andRa4 » December 18th, 2010, 3:43 am
mas ilham, smua udah d-jelasin sama mas benji.
mas benji, makasih banged mas udah njelasin. :">
