M65FW58 ● I LOVE BEESPRING
Postby Hendz » December 11th, 2010, 1:24 pm
The BeeSpring a.k.a Tawon Pegas - by Fish | madFish Company © 2000-2006 | M65FW58 only
Downloads:
http://madfish-company.com/TUNING/MFC/B ... 65sw58.rar
• Sudah temasuk Patch
• Tinggal pakai
Patches Included:
Graphics:
• MEGA GRAPH PATCH Part 1.vkp - 1.49 MB
• MEGA GRAPH PATCH Part 2.vkp - 1.57 MB
• UPDATE GRAPH PACK (by fish).vkp - 368.4 kB
• UPDATE icons (by fish).vkp - 31.8 kB
Systems:
• Mainscreen Position.vkp - 1.0 kB
• System Font 1.vkp - 63.1 kB
• System Font 2.vkp - 110.1 kB
• System 1.vkp - 8.8 kB
• System 2.vkp - 1.2 kB
Image Dua patch di atas (System Font 1.vkp + System Font 2.vkp) jgn dipake (UNDO aja) klo pengen font ttp sama bentukna dg aslina.
Patch Lists:
All These Patch were Integrated:
; * Clean messages * © SiNgle, § Smelter, ® AsteriX
; * Clean software-buttons from the main screen and to lower date with hours downwards v2 * © SiNgle, § Smelter, ® AsteriX
; * Disconnect an inscription "network Search" * © arsh0r, § Smelter, ® AsteriX
; * Clean German and Polish of the menu of languages of input * © AlexSid, § Smelter, ® AsteriX
; * Clean a comma between a name and a surname in the directory list * © SiNgle, § Smelter, ® AsteriX
; * Clean a dialing sound * © AlexSid, § Smelter, ® AsteriX
; * Disconnect a sound "the Network it is found" * © avkiev, § Smelter, ® AsteriX
; * Disconnect a sound in the beginning of record of video * © SiNgle, § Smelter, ® AsteriX
; * Clean a grid from a background at a portrayal of windows, for example "Please Wait" both тп and тд * © SiNgle, § Smelter, ® AsteriX
; * Clean plane acknowledgement * © Bennie, § Smelter, ® AsteriX
; * Change of the name of disks in the choice menu * © DeHuCoH, USV, § Smelter, ® AsteriX
; * Change of a divider in the menu * © *S*h*a*D*o*W *, ® ILL!, § Smelter, ® AsteriX
; * Call-back constantly with the set pause * © SiNgle, § Smelter, ® AsteriX
; * Record of video 1 minute * © SiNgle, § Smelter, ® AsteriX
; * Illumination with step of 5 % * © SiNgle, § Smelter, ® AsteriX
; * Delay of clearing of illumination * © BuG, § Smelter, ® AsteriX
; * Sound Replacement at dialing "a connection error" * © B-727, § Smelter, ® AsteriX
; * Smooth longnames and names * © SiNgle, § Smelter, ® AsteriX, KiRiK
; * Change progressbar at music playing * © SiNgle, § Smelter, ® AsteriX
; * Speed of a blinking cursor * © SiNgle, § Smelter, ® AsteriX
; * Smooth inclusion of illumination * © SiNgle, § Smelter, ® AsteriX
; * Compression jpeg with maximum kach-vom (100 % instead of 75 %) * © SiNgle, § Smelter, ® AsteriX
; * Accelerator * © SiNgle, § Smelter, ® AsteriX
; * Change of time of giving of an every minute signal during conversation * © SiNgle, § Smelter, ® AsteriX
; * Keyboard autorepetition * © SiNgle, § Smelter, ® AsteriX
; * Decimal CID instead of C1 and C2 in the list of the next honeycombs * © thank God, § Smelter, ® SiNgle, AsteriX
; * Menu of disk-choice and display of the latent files and folders * © SiNgle, § Smelter, ® AsteriX
; * Engineering menu * © Phantom, § Smelter
; * Include a range choice * © Bennie, § Smelter, ® AsteriX
; * Open blocked blocks EEPROM * © Skylord, § Smelter, ® AsteriX
; * Open disks forevah! * © SiNgle, § Smelter
; * Clean "Wait" at chamber start (from menu ММС too) * © ACiD [mrp], § Smelter
; * Adjustment of speed and brightness of the chamber (except S65) * © SiNgle, § Smelter
; * Re-enable "Hide ID for next call" * © BuG, ® benj9
; * MyStuff = Disk Menu v0.1 * © cXastor
Menu, Skins, Themes, etc:
Skins:
• Hanya ada 1 skin: SPRING.scs - 21.7 kB
Komposisi Default Graph & FlexMenu:
• Folder "/Config/Default"
• Folder "Config-Japp-FlexMenu"
And ma Personal Review is...
• Batre irit & stabil;
• Didisain khusus utk mereka yg suka tampil sederhana, ga ruwet;
• GUI yg klasik tapi so-cute. SimpeL, elegan, kalem dg ijo-sekunder, informativ;
• Navigasi joystik cepat, cause of FW58;
• Font item-kecil, sama dg The Fallen Angel, tp msh kontras utk ngetik SMS;
• Tanpa ELF;
• Punya patch yg oke juga;
• Punya built-in emo 3D-funky yg cakep:
Image Image
• Tawon sebelah kiri bakal naek turun sinkron dg penerimaan signal GSM 0--100%;
• Tawon sebelah kanan jg bakal naek turun sinkron dg power batre 0--100%;
• Hanya tinggal qta edit wolpeper bawaannya dg pic tawon yg lebih gede, spt saat "network search".
Re: M65FW58 ● I LOVE BEESPRING
Postby mamed_3279 » December 13th, 2010, 12:32 am
Hendz wrote:• Sudah temasuk Patch
• Tinggal pakai
suka yang begini...numpang donlot mas :))
Postby Hendz » December 13th, 2010, 8:24 am
^^^ hajar ajah maz :))
Postby Hendz » December 13th, 2010, 8:35 am
Additional System-Patches for FW58 | SiemensMania.CZ
http://www.google.com/translate?hl=en&s ... s%26f%3D58
TURN-OFF KEYPAD LIGHT
-- Patch ini jangan di-apply coz bakal bikin Predator qta jd tampil cemen bgt tnp cahaya kiped
-- Jadi hanya khusus untuk mrk yg lebih suka ngirit batre drpd tampilan fisik yg super-sangar
;* Disable keypad light *
; (c) SiNgle
; Smelter auto-patch
0B1F24B: D5 24
BOLD FONT ON MENU
-- Mempertebal huruf di semua menu
;M65v58
;(c) SiNgle
;PatchID: 4446
;Details: http://patches.kibab.com/patches/details.php5?id=4446
091BCA4: 02 03
Postby isa.finalidea » January 1st, 2011, 5:11 pm
wah bener skali kata mas hendz, ringan n simple, ga boros batre n ga berat, krn tanpa elf, cuman patch graphic n sistem aja, dah kucobak..apik nih, tp font gak ku apply krn kekecilan n susah kebaca..mantab neh patchnya.
isa.finalidea
Postby mamed_3279 » January 3rd, 2011, 12:08 am
^^bener mas..mantaff :x
Postby Hendz » January 3rd, 2011, 1:10 am
emo na cakep kan? ga jaduLan =)) cm emang rada gede sih.
Lah gmpng aj tinggal ganti ndiri kecilin dulu kira² 16x16 pixL or 14x14 truz patch balik ke FUBU via VKLay. berez kan? :))
tp skrg yg lom ktm & susah dapetna ialah: FLASH SMS di FW58 :((
Postby mamed_3279 » January 3rd, 2011, 9:49 pm
^^ :?: kayanya dulu saya sempet pake flash sms v.58 deh mas...coba liat deh di kibab :D
Postby Hendz » January 4th, 2011, 8:42 am
udah dicoba & masuk patchna. cm gatau makena. dr dulu jg gt. pake <spasi> diawal ketikan jg gamao. klo di SX1 mah enak lgsg ngluarin menu FlashSMS
Postby andRa4 » January 4th, 2011, 9:30 am
Cara pake flash sms:
- Instal patch flash sms.
- Seting ukuran font menjadi Normal (standar).
- Pada saat menulis sms, awali dengan spasi.
- Jika ada yg mo nambahin, silahkan.
