NV ITEMS ● Backup N' Restore
Postby Hendz » December 21st, 2010, 4:20 pm
NV ITEMS ● Backup N' Restore | by SandStorm
Oct 16, 2007, 11:23pm
VERY IMPORTANT, BACKUP YOUR NV FILES FIRST BEFORE UPGRADE!!!
1-> Download QPST 2.7 Build 215 from the web (bittorrents, for example)
------->> additive by Hendz: QPST is right here ----->> http://www.filecrop.com/QPST-2.7-build-215.html
2-> Install it on your computer.
3-> Go to "QPST configuration" to set up the port for your device. Click on 'add new port' and place the correct com. then, activate it. (normally it set up automatically, but some times, we need to do it first.)
4-> Go to "Software Download". This is where you'll backup your NV files stuff.
5-> Select the 'Backup tab'
6-> Take note the folder where it will be placed, as you can change its name. make sure to leave the same file extension!!!
7-> Click on Start.
8-> Done!!!
HOW TO RESTORE YOUR NV ITEMS BACKUP
1-> Go to "Software Download". This is where you'll restore your NV files stuff.
2-> Select the 'Restore tab'
3-> Take note the folder where you have your backup!
4-> Click on Start.
5-> Done!!!
6-> reset the phone, it shall be ok now
Re: NV ITEMS ● Backup N' Restore
Postby andRa4 » December 21st, 2010, 4:51 pm
NV Items apa-an yakh-??
Tolong jelasin dong,. :D
Postby Hendz » December 21st, 2010, 7:47 pm
= Non-Volatile Items = Filesystem yg dipake di OS Brew
Postby Budi_XP » December 21st, 2010, 10:24 pm
Hendz wrote:= Non-Volatile Items = Filesystem yg dipake di OS Brew
Wew Mas Hendz mulai suka pakai Brew (SXG75) ya :)) :)) :)) :))
Postby Hendz » December 22nd, 2010, 10:20 am
^^^ ga tuh? hapena jg ga pny kok hehehe :)) naaa drpd forum Brewna kosong aje :D
Re: NV ITEMS П Backup N' Restore
Postby ilham » December 22nd, 2010, 11:15 am
Moga-moga cepet dapet BREW Maz. :D
Postby Hendz » December 22nd, 2010, 11:36 am
^^^ maziLham dulu aj dech tar aq nyusul... tuh bli aj dr mazBudi, stokna kan msh ada 5 gitu.... tapi @Rp 3jt :))
Postby Budi_XP » December 22nd, 2010, 4:21 pm
Hendz wrote:^^^ maziLham dulu aj dech tar aq nyusul... tuh bli aj dr mazBudi, stokna kan msh ada 5 gitu.... tapi @Rp 3jt :))
Wa Gozippppppppppppppp.... :))
Postby andRa4 » December 24th, 2010, 2:51 am
haduwh,.haduuwh,..
saya masih stengah blind sama dunia siemens.
apa lagi ini OS BREW-??
d-pake d-produk apa ja yah-??
yg saya tw cuma BREW...rimarantika :D
*ups..OOT*
Postby Hendz » December 31st, 2010, 8:29 am
^^^ yapz bener BREW-ri marantika dipakena di...ntar lu tanya ma mbah GuGL dulu....:D
tp klo OS BREW di SXG75 ama EF81...lah anggep aj kyk Symbian gt loh
Return to BREW
