Pocket-LOOX N520 with Mobile Nav 5
Postby Hendz » December 11th, 2010, 12:58 pm
Utk yg suka OS WinMob tp enggan pake QWERTY, klo pake Loox yg ini gimana?
REF: http://www.trustedreviews.com/mobile-ph ... gator-5/p1
... atau kakaknya, N100, yg msh minim fitur:
REF: http://reviews.cnet.com/car-gps-navigat ... 28464.html
Re: Pocket-LOOX N520 with Mobile Nav 5
Postby ilham » December 11th, 2010, 2:28 pm
Harganya kisaran berapa ya KangMaz?
Spesifikasi detailnya dong KangMaz, he3x.. Lagi pakai wapsite nih. :)
Postby Hendz » December 11th, 2010, 3:54 pm
Loox N520 harga pastina qta gatau, distributor na di Indo jg qta gatau.
Tapi krn ini mesin buatan 2005 dan WinMob, biasa anjlok di pasaran. Jadi qta bisa kira aja pasti dibwh 1jt (600-800) tanpa peduli dalemna pk WiFi & GPS or not :D
Loox N520 Detailed Specs:
Release_Date: December, 2005
Dimensions: 71 x 116 x 14 millimetres
Mass: 160 grams (battery included)
Software:Environment
Embedded_Operating-System: Microsoft Windows Mobile 5.0 for Pocket PC Premium Edition
Browse devices running this OS
Microprocessor,_Chipset
CPU_Clock: 312 MHz
CPU: Intel XScale PXA270
Browse devices based on this microprocessor
Memory,:Storage-capacity
RAM_capacity: 64 MiB (accessible: 50.5 MiB)
ROM:capacity: 128 MiB (accessible: 81 MiB)
Display
Display-Type: color transflective TFT , 65536 scales
Display-Diagonal: 3.5 "
Display:Resolution: 240 x 320
Sound
Microphone(s): mono
Loudspeaker(s): mono
Audio+Output: 3.5mm
Control-Peripherals
Positioning-Device: Touchscreen
Primary;Keyboard: Not supported
Directional+Pad: 5 -way
Scroll_Wheel: Not supported
Interfaces
Expansion:Slots: MMC, SD, SDIO
USB: USB 1.1 host/client, 12Mbit/s
Proprietary
Bluetooth: Not supported
Wireless_LAN: 802.11b, 802.11g
Infrared+Gate: 115200bit/s (SIR/CIR)
Serial: RS-232
Multimedia+Telecommunication
Analog+Radio:Receiver: Not supported
Digital-Media+Broadcast_Tuner: Not supported
Satellite:Navigation
Built-in;GPS-module: Supported
Complementary_GPS;Services: Not supported
Additional:Details
Battery: removable
Battery;Capacity: 1200 mAh
Postby andRa4 » December 11th, 2010, 7:33 pm
LIKE THIS :x
Postby gandalf » December 11th, 2010, 7:36 pm
btw ini cuma PDA saja ya? bukan PDA phone ??
Postby Hendz » December 11th, 2010, 8:15 pm
ho'o maz. khusus PDA + GPS Nav. Coz depannya ada "N" (N for Navigations)
klo yg ada hapenya kykna cm ada dua (T830 + T810) viewtopic.php?f=119&t=1046
Postby gandalf » December 11th, 2010, 8:31 pm
T berarti Telepon :P
Postby Hendz » December 11th, 2010, 8:45 pm
gandalf wrote:T berarti Telepon :P
naaaaaa ntu maz dah tau, baru jg aq mao omongin =)) =))
Postby gandalf » December 11th, 2010, 8:47 pm
tak pikir2 lagi N itu NELPON =)) =)) :)) :))
Postby kokakokbrut » December 11th, 2010, 8:50 pm
SL45 juga PDA koq ga percaya ?
PDA = Phone Dengan Antenna
Return to Fujitsu Siemens PDA Phone
